WE MOVED...
filling lacquer scratches
Jeff
I have a coffee table top that I need to refinish. The existing top is scuffed and has lost its shine, so I plan to clean any wax and contaminants from the top and then spray several coats of lacquer, after which I'll rub the finish out. Unfortunately, though, there are several scratches in the existing lacquer (not into the veneer) which will translate through any new coats, so I am looking for a way to fill them prior to spraying.
In the past, I've used clear epoxy to fill these types of scratches, but epoxies always yellow out more than the topcoats. I've also brushed numerous coats of lacquer into scratches and then sanded everything flush before spraying; this process works well, but takes time. If the top were shellacked, I'd simply French polish the scratches away, but the top definitely needs to be lacquer. My client doesn't want to pay for stripping, re-staining, pore filling and finishing, so that route is out, too
I'm curious what other techniques have been used for filling scratches. Any advice?
Re: filling lacquer scratches
Re: filling lacquer scratches *LINK*
Dick Coers
My first thought was burn in sticks. I thought they only made colored, until I checked Mohawk. They make a clear. I've never used these, but should be faster than lacquer build up since you could do it on one application.
Mohawk burn in stick
Lacquer dissolves itself....
Tim Greif - West of Chicago
It's much like shellac in that regard - it dissolves into and bonds chemically to itself. If this is true lacquer, I'd use an artist brush to fill in the scratches with new lacquer until it's above the level of the existing finish. Then you can wet sand it (think car finishing in the old days) to level everything perfectly flat going up to 600 grit. Lubricate the wet sanding with water having a drop of dish soap in it for lubricity. Then buff out with automotive rubbing or polishing compound to get the desired gloss. You should not be able to detect the scratches when you're done.
At least that's what I did on the old cars and motorcycles I painted. Never did it on furniture, but I can't see what the difference would be.
a better alternative to Mohawk
Bill Tindall
I have one more IWF report left to do and its spot on to this discussion. Stay tuned for tomorrow morning or late this evening.
FredD
Tim's method works well.
I keep a small bottle (about a fluid oz) filled with Lacquer that I have let the solvent mostly flash off before sealing it with the cap.
This greatly thickens the lacquer and mades short work of filling scratches.
Burn in sticks work well too but the application is a learned skill, not one you would try out on a client first thing without some practice.
FredD
