Hot Belts . . .
steve mackay
Is it just me or do sanding belts seem to cut slower when hot ?
Hot Belts . . .
steve mackay
Re: Hot Belts . . .
Not you. That's why I have had a graphite pad mounted on my belter for may years. I also use a sanding frame to keep much of the belt off the surface. This not only prevent gouges and creases, but also helps cool the belt.
As the wood heats, the lignin softens, which decreases the abrasive's ability to cut the "softer" surface.
Re: Hot Belts . . .
FredD
Your snding belt is running hot most likely because it is loaded with wood particles and whatever else your sanding , like wood filler or crack filler.
I use a large stick of gum eraser to keep the belt clean and the belt wil last much longer and work better. Al of the craft stores carry them.
FredD
Re: Hot Belts . . .
steve mackay
Not really. I'm pretty religious about applying the snot-block after every move. I like to keep 'em clean so they last longer. Probobly three times longer. I'm sure they just warm up due to friction (despite the graphite pad underneath). They just seem to not cut as well when they warm up. Not a great problem, only an observation.
Re: Hot Belts . . .
FredD
Then your doing all you can besides letting the machine cool , don't worry about it.
If your letting the belt heat to the extreme of it's splice letting go , you might want to change tecniques. Or not.
FredD
Sort of. They get hotter when dull.
Keith Newton----Little Rock, Arkansas
If the abrasive particles are sharp, the dust should take away some of the heat with it. When the belt dulls, you get more friction with less wood being removed. And of course, as already stated, loading also adds more friction.
