We value your privacy.
I have been posting about this table my son and I were building. Thanks for all the advice. The top is two 16" wide bookmatched boards that were resawn from a single board about 1 3/4" thick. They warped in every direction, but we were able to flatten them. The frame and legs are osage orange. The legs came from a tree that blew down in the yard of a historic house. Someone here at Wood Central sold me the longer pieces for the frame. (Forgive me, I can't remember who.) The legs are mortise and tenoned and pegged with cherry dowels.
We did widen the top bay about 3 1/2" on each side.
The size and shape of the frame and top is very pleasant, and I'm sure the bookmatched character of the top will be very remarkable once you are done with the finishing schedule. The cherry may darken/redden-up more quickly than the osage's color and tonal change, and therefore be a mis-match for a while. However, a little patience will validate your wood selection. The frame and legs are going to set off the top quite well. It will be interesting to see another picture in a year or so to compare the two images. Nice table, and nice job. How'd you chop the mortices?
We tried the larvae that tunnel trough the Osage, but they were too large to get good sharp corners, so, termites were brought in and trained.
Actually used A hollow chisel attachment on the drill press, Half inch mortise 2 1/2" deep by 3 1/2". Osage is HARD. I'm pretty sure my right arm is longer than my left from pulling on the handle. Cut the tenons on the TS with a Tenon jig. One was too snug and my son was working on it. He shaved the faces of the mortise to no avail and then finally figured out the tenon was too wide, not too thick. You have to learn somewhere. It's his table. We shimmed it with a piece of brown paper soaked in Epoxy. The joints felt really solid after the epoxy set.
The legs have the inside corner cut off at a 45. That was done to get rid of a bark edge on one of them. It turned into a design opportunity and made the rather massive legs look considerably lighter. It also provide a flat surface across the inside corner of the leg inside the frame. We ran a brace across that surface and screwed that to the leg and the frame. Probably was not necessary but was easy and may have added some strength. Not sure the dowels in the legs were necessary either, but he liked them and they "couldn't hurt".
Looking forward to more finish on it and its darkening over time.
