Your preferred blade width for curve cutting?
My Delta 14" blade had an "accident". We WILL NOT discuss what sort of accident. I find myself in need for a new curve cutting blade. My minimum radius would be on the order of 2".
I was figuring on a 3/8" 3-4 TPI. My maximum stock thickness is on the order of 2 1/2". My minimum would be maybe 3/4 (possibly 1/2"). What else should I consider? Skip tooth, raker tooth or what? I've got a 1/4" spare that I don't really use, so I'm not dead in the water by any means.
TIA
Re: Your preferred blade width for curve cutting?
Ken Oakley-Sunny St. Cloud, Fla
I prefer 1/4"- 6, 10, or 14 TPI depending on wood and thickness.
Re: Your preferred blade width for curve cutting? *LINK*
There are various tables of the curve radius possible with different bandsaw blades. One is linked below.
I'll step back now and let others talk about tooth patterns and so on; but you might see if your local library (or library system) has any books on bandsaws, like any of Mark Duginske's books on the subject. As I recall, Mark Duginske goes into some detail about tooth patterns and their tradeoffs.
Scroll down a bit
FredD
One need go no farther then Duginske on bandsaw set up and tuneup and use. Very useful books by him.
FredD
