200+ woodworking book reviews
Ring box hinges
Ring box hinges
Ring box hinges
doug f, san clemente, ca
I'm designing a small ring box for an engagement ring and having trouble locating what I call "snap" hinges. There the ones on most ring boxes that hold the lid open and then "snap" closed and hold the lid tightly shut.
Anyone know of any sources?
Oh, by the way, the reason I'm looking for these hinges is that the box will be made from a chunk of Koa about 4"x 4" x 4", split in the middle with the cavity for the ring carved out.
Thanks for any help.
Doug
Re: Ring box hinges
David Barnett
Try searching for 'spring' hinges *LINK*
David Barnett
Although there are spring hinges available (try Rocker), many ring boxes have standard small hinges and employ a separate hidden spring of flat metal or music wire to do the trick. These are easily made or scavenged from another box.
Patents are a good place to see drawings and get ideas. Go through the cited and referred patents for more.
Here's one to get you going
Re: Ring box hinges
Re: Ring box hinges
Norm Knoxville
Doug, go to Zales and ask for a box. You may have to buy it, but you have a hinge.
Re: Ring box hinges
Re: Ring box hinges
wodturner
Visit your local Goodwill or other thrift/second hand store. Used ring boxes go for 25 cents or so. Buy a few and head back to the shop. Remove the parts you need from the boxes and your Good To Go.
Regards,
