We value your privacy.
A foam plastic cylinder sold on a roll and in various diameters. It is used to stuff cracks in material being caulked so that excessive amounts of the more-expensive material will not be wasted filling a large void. This link is wood-related and therefore not strictly OT.
That's not exactly he purpose of Backer Rod. While it may serve to save some of the material, it is actually designed to use under wide caulk joints so that the joint is wide or thick where it contacts the edge of the joint, thin in the middle and wide at the other side, so that a cross section of the caulk joint would look like a bow tie rather than a big thick wad. Then, when the joint expands (the materials contract away form each other, there is an excellent bond at each end of the bowtie and the thin part in the middle stretches, or if the joint shrinks (the material expands) the bowtie is crushed but unharmed. If you fill such a joint with the caulk, the bond will fail when the material shrinks, because it can't stretch the big wad of dried caulk, and the material may be nearly incompressible when the joint tries to contract. This is why the tar strips on roads are made of permanently soft tar. In cold weather the tar subsides and the cracks become grooves, but the tar still seals the joints. In hot weather the road expands, the cracks become smaller and the tar is pressed up and out of the joints and you get the bump bump bump of riding on a hot concrete highway. (It occasionally gets so hot locally that sections of the road "explode" from the internal pressure.)
For your driveway, you must have a fairly large crack if the wheel of your TS got hung up in it. I suspect that if it is that big you will have trouble with anything soft you put in the crack. If you put tar in it your wheel might be tracking tar into the shop. If you caulk it with backer rod under the caulk you might punch into the caulk and have the same problem you have now and will have damaged the caulk.
Is the crack a nice straight line? Could you clean it out and insert a piece of treated wood into it? Something like a 1x2 or 1 x4" piece. If the crack is full of sand and gravel, you may be able to blow a lot of it out of there if you have an air compressor. And, If you put the TS in the same place every time, you only have to do the spot where it goes. If that works, we have successfully made this a woodworking project. It could be a combo of wood and excellent caulk.
You can also fill the crack with "swimming pool" caulk. Something probably from Thiokol or Pecora. Fairly expensive stuff, but tough. Might use backer rod everywhere except with the TS goes.
Don't know what climate you are in, but the more extremes the temperature changes are the more you need expansion joints. The bigger and longer the drive is the more you need them. (An Admittedly poor rule of thumb is that any piece of concrete under a thousand square feet doesn't need them. Any Piece of concrete that is three times as long as it is wide does need them) Locally, most of them are put in as "control Joints" more than expansion joints. Control joints are cracks put in in intentionally tho keep it from cracking randomly on its own. So, yours already has the crack and unless there is a lot of expansion and contraction (ever seen the crack close up?) it may be serving as a control joint more than an expansion joint, so you could fill it with wood or concrete.
That is a good explanation of expansion joints and their use Barry.
When you mentioned Swimming Pools it brought back memories of being on the bottom of the Totem pole.
I first worked as a Apprentice Carpenter for J.N. Davis Inc, , at the time the largest Custom house builder in Whicita , KS. and my first cousin.
One of the main parts of his construction company was a franchise for Penguin Pools ,still in business with his son now.
On home size and Municipal size pools my job as a Newbie was to run the Tar Pot and using a long necked sprinkle can without the head , carefully pour all of the expansion joints after I had used a hay hook to remove the 1/2" x 4" felt that was in place for the concrete pour.
Naturally this took place in hot Kansas Summer Weather , down in a nine foot deep hole and with sweat running down into my eyes, sometimes I got the Tar on the pool bottom surface.
This meant the next morning at daylight I had to get on the job and hope it was cool enough to scrape off the dribbles.
That ws a long time ago and Tar was the agent commonly used, it may be different now, but tar is still very effective for gaps in Expansion joints, see it nearly every day.
I have seen attempts to use cement to close a gap beween slabs and it invarialby crumbles when the slabs move the next time the season changes. Caused by zero flexibility in the cement.
