WE MOVED...
OT - How to clean brick fireplace?
Hoa in Alameda
I'm commissioned (no pay, however) to clean a red brick fireplace. It's in the family room so power washing or muriatic acid is out of the question.
The condition of the bricks are not bad, no efflorescence, just dust and smoke residue.
What is the least toxic and the least messy chemical I should use?
Thanks.
Re: OT - How to clean brick fireplace?
larry in kansas
If memory serves me correctly, TSC is something you can look at. It`s suppose to be good for cleaning some fairly tough things. Good Luck Larry
Frank Orfanello
Did you mean TSP (trisodium phosphate)?
I've used that with good results. Just a warning I have to wear rubber gloves or my hands get destroyed.
John Veerkamp
TSP is what the professional's use to clean up after fires. It is less toxic than most heavy duty cleaners. If you have carpeting or wood around the Fireplace, be sure to protect the surface with plastic sheeting. It can discolor the carpet and remove/damage the finish on wood. It works well. There is also a substitute out there called"TSP" but it is not the same. Most paint and wallpaper stores and some hardware stores carry the real thing.
John
Dale Warder
I found a fireplace cleaner for brick fireplaces at Lowes last year. It worked well, much better than I expected, and with minimal mess. The fireplace looks almost new afterward. Sorry, I cannot recall the brand name, but it was in the cleaner section of the store
Dale Lenz
Dale Lenz
I'd bet Easy-OFF, yellow can, might work, used it to clean fireplace smoot off of glass. Can not say what affect the lye will have on the brick and morter. If you try the Easy-Off, proceed with caution, wear gloves also.
Howard Norman
I seem to recall that real TSP can not be sold in CA.
Galen Vetterick
I still have two "Smoke Off Sponge" By Gonzo. They are a red dense foam pad sold to remove soot and dirt on a brick fireplace or wood stove. I assume you can still get these. Used dry and you clean with water to reuse.
Very similar to wallpaper cleaning sponges and maybe even those work.
Bill Turpin in WNC mountains
I saw thw stuff at Lowes today. It is potassium hydroxide. It is a little milder than caustic soda. PLEASE USE GLOVES!
TSP and ...
Hoa in Alameda
Went to Lowes' but could not find anything specific for cleaning bricks so I picked up a box of TSP.
Armed with a bucket of TSP solution, a stiff brush, some sponges, some towels, and a pair of rubber gloves, I spent about 2 hours cleaning the bricks.
The result looks very very good. SWMBO is happy.
Thanks for the help.
But frankly, I suspect that elbow grease, not TSP, played a greater part in this.
-- Hoa
