wood for a small bridge
Dave Long
I need to replace some old wood on a bridge. Main problem I have had is bridge is in shaded area and when wet, wood remains slick for a long time making cross structure dangerous. Anyone having any suggestions on products which are long lasting and give good footing??
Re: wood for a small bridge
Clint Searl
Clint Searl
Overlay the wood with stucco lath.
Clint
There is a product called Shark Grip. This consists of small "microspheres". You add it to paint, urethane or another coating. It is typically used in boating and waterside applications. If you were going to paint or coat your bridge, this would work. I've used it in finishing a dock. Works nicely.
Another choice is to add a finely divided sand to a coating. I don't like it as much because of the sharp edges of the sand. I've also used epoxy fiber paint to give a non-skid surface to a concrete floor. It may work for your application.
Jim H
I built my deck using one of the composite decking materials from the borg. It won�t rot and it is fairly slip resistant without any additional coating. If you needed extra grip you could mill more prominent ridges into the face.
Galen Vetterick
Just do not let the wood soak up water and stay wet.
Should be no problem if you treat it with Thompson Water Seal.
One section of decking and a series of wood steps always in the shade never got slick as long as I treated about every two to three years. Very easy to recoat with the hand pump sprayers.
