Followup on H&L sandpaper and bandsaw blade questi
Robert R. Clough
Some of you may remember I asked about H&L sandpaper sheets recently. I did get help. However, I recently received my Highland Woodworking cat.
Lo and behold, on p 57 Highland has Norton H&L 9x11 sheets in 3 and 20 pack from 60 through 400 grit.
Just thought I'd let you know.
Now a question on their Sterling bandsaw blades. I am less than content with Olson, but they are inexpensive. Have any of you tried thte Sterling brand? I do little resawing and do not need the Woodslicer blades.
Thanks
Re: Followup on H&L sandpaper and bandsaw blade questi
the best band saw blade prices
bill tindall
About any saw shop stocks bulk rolls of quality blade stock and will weld a blade up to your specifications. For a 14" saw they are less than $10 for Starret or Lenox blades at our local saw shop, Mesenheimer.
Re: the best band saw blade prices
Robert R. Clough
Bill, what is a saw shop? Probably Milwaukee has something that will do what you suggest, but this is the first I've ever heard of them.
"Saw Shop" defined
Bill Tindall
"Everywhere" will have a local or at least regional saw shop that caters to the needs of the woodworking trades for that area. We have at least two and they are in Morristown, TN. Taking the example of Meisenheimer they sharpen and repair anything that cuts wood or metal, they make tooling for molding machines and the like, they used to make saw blades and they are a distributor for companies that make stuff to cut wood- Wisconsin, Lenox, Starret, etc. Depending on the woodworking activity in an area your saw shop may be somewhat more or less capable. But at a minimum there will be some place that sharpens and repairs cutters and welds up band saw blades. The blades for my 20" saw cost about $11 and I can choose from a large selection of tpi and blade width.
To find one, look in yellow pages or ask at a local woodworking shop.
Thanks, Bill NM
Robert R. Clough
