A55 Smoothing Plane
OT TV Converter Remote Donna Work
Al Kapocius
The remote for my two year old TV digital converter doesn't work right. Maker (on both Chinese made remotes) shall remain anonymagnavox. Several numbers and functions don't work when depressed except when really really pressed with a nail file and then not always. Same locations on both gadgets.
The remote consists of a top and bottom plastic shell, circuit board with (IR?) light with two AA batteries and a third piece, a molded rubber layer with hollow indentations under the keys. The circuit board at keypad locations appears to have three short parallel wires under the green insulation coating.
Is there a secret incantation or fancy trick to make these reluctant keypad locations work? Can I spit on the keys or tape tinfoil on the pad locations? Inquiring and frustrated minds want to know.
Al Kapocius
Re: OT TV Converter Remote Donna Work
Gary Smyth
Give that remote up for dead.
You can go to any electronics store a get a remote. In the package will be a list of codes for the various TV manufacturers. By following the directions and choosing the numbers listed for your Magnavox and going through the codes O-N-E by O-N-E (snore) you can likely (not certainly) hit the right code and then...Bob's your uncle!
I did this several times and it works--however. on one set it was the TV receiver that went out. For that TV it was a manual on off, and the cable box, after the TV was turned on still allowed remote channel changing.
Jim Rahbe, Bedford Texas
Two years is about right.
Al,
On the back side of the rubber piece, the side that touches the circuit card, there should be several dark �spots�. These spots should be directly under the buttons. The spots are made of a graphite like material. When you push the button, the graphite connects two or more of the circuit card �wires� or traces. Unfortunately, the cheaper the remote the thinner the graphite, which wears off or gets dirty. Two years sounds about right. You can clean the graphite pads with alcohol, that might fix it for a few weeks, but you need to be looking for a replacement. I know they make universal remotes for TV�s, but I have no idea if they make them for convertor boxes or not. If it were me, I�d be looking to pick up a new convertor box, as they are relatively cheap..
Regards,
Jim R.
Thanks I think, Mucho Grass
Al Kapocius
