Magnetic Switch Question
I posted recently about the fact that the remote switch for my DC Failed. It was a Long Ranger By Penn State Industries.
Today I bought a contactor from a used industrial tool dealer. Its a Square D device that has a magnetic switch and "heaters". the magnetic coil is clearly rated for 120 hz. When I apply 120 to the coil, it snaps the switch closed and makes contact, but the coil buzzes. Fairly loud. So, is this normal or should it close and remain silent wile the machine is running.
Re: Magnetic Switch Question
Brian Aust
I'm assuming you meant 120 volts on that coil, do you know if you actually have 120 volts, + - 10%? Low voltage can cause them to chatter, also if it is a used contactor the contacts might be pitted, take the cover off and look at the contacts - power off of course! You can usually get a kit with new contacts and springs. Check all the terminals for tightness. But sometimes there's not much you can do, some contactors just like to buzz.
Took it apart and cleaned it. It had about a pound (teaspoon) of crud in it and it apparently had been wet or in a corrosive environment, the metal frame of the coil was rusted. Dumped the loose crap out and blew it out and wire brushed the metal surfaces. the contacts themselves were in good condition. Seems to work fine and makes solid contact, just buzzes.
del schisler
the coil is over lamanation's which are metal. Now they are probly loose. The coil and lamanations should be tight. Can you get to the coil and use a wooden like screw drive and move the coil like wedge it. If it quites the lamanation's are loose. Than wedge it. I bet it in incased in plastic? A new one is in order. I been in radio and tv repair and ham radio transmiter repair. Their are lot's of relay's . Sometime's we had to wedge or tighten up power transformers bolts . They like to hum also.
Bill Howatt
Like del said it is very likely the coil/laminations vibrating from the AC magnetic field. If the contactor snaps in well then it is nothing more than an annoyance if you can't tighten something to stop it. It's the same thing that makes flourescent lamp ballasts noisy.
Does it buzz as loud if you mount it in a different orientation?
Hopefully the sound of your tools running will hide it from you. If it doesn't then consider it as an optional feature: An audible alarm that the contactor is energized :D .
Bill
Jesper, Denmark
Jesper, Denmark
Barry,
Contactors, starters and other coil operated devices should not buzz or chatter when activated. The should cloe with a clear snap. and then make no more noises.
From your description, it was a used contactor - maybe a false economy. Does it have an auxu�liary holding contact for the coil? If not, it limits your remote wiring possibilities.
Bill Howatt
He did say it snaps closed. I think the issue is "what does the buzz sound like". I agree it should not be chattering and making an obvious severe vibration but if all the contactors that make a relatively loud 60 Hz humming sound there would be a large number of them in the dump.
If they are in top condition then yes, there should be very little sound from them.
Bill
Bill Turpin in WNC mountains
Bad contacts for the motor WILL not cause contactor hum, especially with no load attached. The heaters or adjustable overloads MUST be matched to the motor's FLA, full load amps. Set for nameplate amps...they will trip at 15% above FLA. Heaters, an older technology, are calibrated heat coils that have very limited amp ranges (about one amp). If they are not set properly you will not have any overload function or nuisance trips when there is no overload! This is why it can be stupid to buy used contactors. Do you have the overload info? Do not operate for long without the metal box cover. The heaters generate a calibrated amount of heat that will not trip the overlaod, by themselves. When an overload occurs, the overloads trip. The cover is part of the heat calibrations. The overload will not trip as soon as necessary. The lamination block can be GENTLY sanded to remove rust. Be sure all waste is removed.
