Mostly OT - "Outdoor plumbing enclosure"..
We have reasonably mild winters up here in the North GA mountains. We get occasional cold snaps and periods where the temperature might get down to the 20s. We rarely get down below 10 degrees.
That being said, I've been asked to install a paddle operated horse "drinking fountain".
I would rather not answer any emergency calls about the PVC pipe rupturing. I was figuring on mounting the waterer with a pressure treated 4 x 4 as the upright and a PT 2 x 4 as the cross piece. I was going to trench the pipe to the watering station well below the frost line (12-18").
The problem is the exposed pipe. I figure that insulating the pipe with the foam insulation isn't enough. I could possible enclose it in insulation and an outer "shell" of 2 or 2 1/2" PVC. I could also build an enclosure - say box in the pipe with the 4 x 4 as the "back wall" of the enclosure and use PT 1 x 6 and a bit of insulation to enclose the insulated PVC pipe.
Any thoughts?
TIA
