Fastening corners on hardwood picture frames?
DouginDenver
I have made several picture frames and have always made the moulding wide and thick enough to use at least a "0" biscuit at the corners to make assembly pretty easy. But now I want to make a few much smaller/narrower ones. I tend to use fairly hard woods - like brazilian cherry or padauk - so the commercial, hammer-in corner fasteners don't seem like an option. I also don't want to invest in the mini biscuit joiner for just a frame or two. So what are some options to join a 45 degree miter in a very hard wood where the moulding is only say 3/4" or so wide?
Re: Fastening corners on hardwood picture frames?
Brads
One traditional method is to drive brads into each corner from two directions, like this:
Brads, which look like a tiny finishing nail, are available at your local hardware store, and come in various gauges* and lengths. Pick a gauge that feels right for the frame size. Pick a length that will follow the usual rule of 2/3 of the nail length being in the nailed-to piece, if you can; otherwise, as long as possible.
You drive the brads in roughly in the center of the miter. Pre-drilling is not a bad idea for the "nailed-through" piece of the frame, if you've got bits small enough, but may not be necessary, depending on the wood.
If your frame profile is designed for it, you can often drive the brads in a location that won't be visible from the front; otherwise, you can set the brads and putty over the holes, or disguise them in some other way. I've seen older (as in 1900-era) frames on which they just darkened the nail head somehow and left them showing. On a dark-stained or dark wood frame, it's not noticeable at all.
This sounds flimsy, but is surprisingly strong; again, those 1900-era frames (from my grandmother's place) are still intact, a century after the pictures were installed.
*Brads use wire gauge practice: higher number means smaller diameter.
Oh, and clamping the picture frame *LINK*
Traditional picture framing clamps - one example at the link below - are designed to give you clearance at the miter, so you can nail the frame up while it's clamped.
One example of many
Nicholas Tuzzolino
Doug:
I encountered the same problem a few years ago and found at woodhaven.com a mini biscuit kit. The biscuits are narrower than a dime. A real life saver when dealing with harder hardwoods.
Howard Norman
I have made a lot of picture frames over the years using the methods that Bill H mentioned along with yellow glue. I have never had a picture frame miter open up over the 30 years or so that I have made picture frames that way.
FredD
I use Cryanocrylate Glue in it's gel form and a accelerator for most picture frames , have for years , can't be beat for speed and ease of assembly,especially for small frames.
Sometimes I will use a 1 " pin rather then brad if the joint looks like it would benefit from a mechanical fastener.
I would suggest you practice on scrap a time or two to get the knack of putting the joint together .
I typically spread the glue on one side of the joint and hit the other side with a shot of accelerator and rapidly form the joint on top of a sheet of wax paper to keep from bonding to the bench top.
For frames that are rectangular in shape glue a long side and a end and then join the two pairs.
Before I apply the glue I rub the side of the joint across a flat piece of sandpaper to knock off any anything that would interfere in a perfect alignment.
Lastly , keep a can of Acetone handy in case of unintended consequences ;-))
FredD
V-nail  *LINK*
Grant in Iowa
Here's a tool that will work with very small picture frames (see link below). They also make a more robust unit that includes a lever press to force the v-nail into the wood. I see no reason that this wouldn't work for your application.
I have also just glued them up in the past. I periodically have wondered about if and when the joint will fail, but several of mine are fine after ten plus years of hanging on the wall. Make up a sample with just yellow glue. You might be suprised just how well the joints hold, even though we have all been told that end grain to end grain isn't a good glue surface. Your experience with dense tropicals may vary, however.
You could also use splines milled into the corner after the joint is glued up and dry. I do this on larger frames most times. The spline can be made to either match or contrast with the wood used for the frame stock.
V-Nail tool at Rockler
Pilot Hole Trick
David Yoho
The best pilot hole for a small brad or even finishing nail can be made by cutting the head off one to be used, chuck it into your drill, and bore the pilot hole with it. Then simply tap in the brad.
Glue-Only Trick
David Yoho
When gluing an end grain miter doesn't lend itself to the use of mechanical fasteners, there's a trick that I've used that works well. This works with yellow glue but works better with liquid hide glue. The reason hide glue works better is because it readily bonds to itself when applying new over old. Smear a thin amount of the glue on the end grain pieces. In the case of hide glue, it's okay to let it dry but yellow glue should be tacky before proceeding.
The end grain will absorb the glue, which acts like a primer of sorts. Too many times end grain to end grain glue joints fail because the single application of glue is absorbed into the grain and the joint ends up being dry. Follow the initial "primer" coat with a normal application of glue and clamp together to dry.
While this method is not a guarantee the joint will not fail, it increases the chances for success.
Don
On thin frames, I've had success using yellow glue on the joint, let it dry, and then add a 1/16 inlay on the back side of the frame joints. Just pass a straight router bit (1/2" or whatever size suits the frame dimensions) across the joint about 1/16" deep. A simple jig can be made for making the cut on a router table OR a straight edge can be used for the router on the frame. Then cut a 1/16" thick x 1/2" (or whatever size bit used) strip of hardwood that fits snugly in the routed "slot".
Cut off pieces from the strip for each 'inlay' and glue with yellow glue. This has been a very strong reliable joint for me.
Kneale Brownson
Re:An old and excellent Pilot Hole Trick
Kneale Brownson
David's trick is the best I'd ever heard of (many years ago) for installing hardwood trim, where a finish nail frequently will bend before it gets through.
I Agree Kneale,
George Colonel's Workshop-Havertown PA
I Agree, Kneale,
David almost hit the nail on the head with that one.
George
A hole lot of punnin' goin' on there
End grain joint
Lee Schierer McKean, PA
Mitered corners are essentially an end grain joint and need to have extra glue to prevent glue starvation. You also need a pretty smooth cut. Most hand saw cuts are not smooth enough to give a good glue joint. I find I get very strong joints if I coat both sides with a liberal amount of glue. to insure the joint is fully wetted with glue. You can also thin down some glue and size the joints before assembly.
Lee
Re: Glue-Only Trick
With PVA glue, I fill the end-grain by using my index finger as a squeegee to force the glue into the grain, leaving a solid film on the surface of the miter. I always use some sort of mechanical reinforcement, usually a "feather" (or a double feather) of 1/8" thick wood glued into a saw kerf across the corner.
That Feather
would have its grain running across the joint, right Boss?
Yes, grain perpendicular to miter
Another Method
David Yoho
When making the base molding for my blanket chests, I use another miter reinforcement that is invisible to the finished piece but prevents the parts from separating. I first glue the mitered parts and put them together to dry. Then I use a forstner bit to drill down about 1/8 - 1/4 inch on the inside flat surface across the miter (see photo).
On a piece of scrap I use the forstner bit to just mark the outline of a circle that I then cut out at the bandsaw. The idea is to cut out a round disk that will fit snug into the shallow hole you cut earlier across the miter. Glue the disk into the hole and the miter will become a strong joint.
