Barry Irby..regarding sharpening a bandsaw blade.
Marv
Barry,
A couple years ago I reconditioned and sold a Disston No.4 vise designed for filing bandsaw blades.
Here's a couple pictures of it.. The hangers on each end of the jaws are for adjusting the blade height. There's one of these on eBay this morning, but doesn't have the hangers. Hard to fine one that does have the hangers. The one in the pictures below sold for about $175 if I recall. One that hasn't been reconditioned will sell for much less.
The price you pay for a new band saw blade these days, I don't blame you for wanting to sharpen them. Some people make their own clamping device out of wood and use their bench vise to accurate the jaws.
Marv
Re: Barry Irby..regarding sharpening a bandsaw blade.
Hand-saw vise
Marv, that Disston vise is really designed for handsaws, though I imagine you could use it for bandsaw blades, too.
David Barnett
I sharpen mine on the bandsaw... *LINK*
David Barnett
... similar to this YouTube video but with a jig I made for angle and depth of grind that indexes to whatever tpi I'm touching up. Freehand works fine for most sharpening, though. Why the saw vise? Am I missing something? Happens.
Freehand bandsaw blade sharpening
Re: You are right, however
Marv
Ellis...
You are right, it can be and is used for filing hand saws, but the hangers are specifically used for maintaining a constant height of a band saw blade as it is filed and then moved for the next length of blade to be filed. No other saw vise that I know of is equipped with the hangers, making the vise unique.
The guy who bought the vise from me uses it only for hand saws.
I posted the vise for Barry just to let him know that he is not alone when it comes to wanting to sharpen his band saw blades. It was common practice to some degree way back when.
Marv
Re: I sharpen mine on the bandsaw...
Marv
David,
The vise was used before grinders came along. But I do like the Dremel grinder better. That's for posting. I learn something new in here almost everyday.
Marv
Dual purpose hangers
Those hangers are handy for keeping your hand saw from dropping down between partially closed jaws and ruining the set of the teeth, too. The adjustable swing allows you to compensate for the taper of the blade.
Interesting. Thanks for the new insight.
David Barnett
And here's a freehand for the gullets, as well... *LINK*
David Barnett
But a cheap fine grit diamond file works well, too.
More cheap thrills in the shop
Re: Dual purpose hangers
Marv
Ellis,
Actually, the hangers don't hang down low enough to hold a typical saw width. The hangers have to be removed or turned around in order to insert a saw blade down more than about 2 inches.
Marv
Re: And here's a freehand for the gullets, as well
Joseph Mulherin, Sr
David, how many times can you do this on one blade before having to buy a new one?
Marv
I like that way of doing it even better, as long as the round grinding stone doesn't get smaller and smaller too fast.
It might be helpful after all the teeth are ground, very very lightly joint the front edge of the teeth to even up all the teeth and knock down the slightly longer ones.
Marv
Aha! Thanks for the added info
Round diamond files
... are the key. EZE-Lap and others make them for chainsaw blades.
Thanks Marv, That's a good idea. I am thinking about looking at a Harbor freight chain saw sharpener to see if it would do a bandsaw blade. I wonder if you could combine it with that sort of blade vice?
And David, I have sharpened some blades on the saw and actually used both methods. I guess my problem is that I end up the blades that will do OK for cutting thin stock but are not good for bowl blanks or serious resawing. Either I am not good at it or maybe my hopes are set too high.
I think I will try the diamond hone.
Marv
Barry,
Looks to me that doing it on the saw is really the way to go if you are using a grinder. No need for a vise. That would just slow you down. The vise was meant to use a file similar to filing a hand saw.
After a few sharpening,s and maybe even on the first sharpening, you are removing some or most of the set in the teeth. There's not much set to start with. Depends on how much grinding you do and if you are grinding very close to an equal amount off each tooth. When you are free-handing it, there is no way you will do all the teeth the same.
Without adequate set you will for sure have problems when sawing something thick and also sawing curves.
You can reset the teeth with a good saw set such as a Stanley 42X. The 42x has a plunger that clamps the blade just before it bends the tooth. If your blade has hardened teeth, you'll probably break teeth off though.
Without resetting the teeth, I'd guess, if you are careful to not grind too much off, you can sharpen it maybe two times, three at the most.
Have fun,
Marv
Lets See that with the saw running...
If you could sharpen it with the saw running the process would go a lot faster. :)
David Barnett
I don't sharpen often
David Barnett
Firstly, let me say I don't know more than the next guy about bandsaws and bandsaw blades. I've sharpened mine since I bought my bandsaw, mostly to correct some lousy blades, and because it took forever to order them pre-WWW.
My 3/4" 3 tpi blades have way more life left in 'em than I do. Usually, when I sharpen it's because I've put a blade through hell; cutting brittle plastics or thick aluminum or highly-silicaceous wood species. Plateaux briar burls are hard on blades and I may resharpen after a only a couple.
Mostly, I just run them until they get hot too quickly and shriek like banshees and the lights dim, and even then, in some species, I'll abuse them further. Also, I don't do the gullets every time -- maybe once in three or four touch-ups. Besides, some materials seem to do better with a less than freshly sharpened blade. Not a very good answer, I'm afraid. Really, I'm not sure I've bought more than two blades to replace ones I've used up.
Fine-tooth blades, 10 to 14 tpi, say, get top edge and gullets each time, btw, and usually with diamond files rather than the Foredom.
Both the guys in those videos have a heavier hand than I do.
David Barnett
Yikes! But if you don't care about the gullets...
David Barnett
... you could hand turn the blade in reverse while holding a bench stone against a few inches of teeth. I've seen that done.
Using a dremel?
chuckbeck
Did I miss it or did someone mention using a rotary diamond burr bit in a dremel tool? Leave the blade tensioned, give each tooth a couple even passes inside the gullet then a quick pass on the outside and fly through a resaw. I think I've sharpened my Olson blade twice now and it just flies through everything.
http://www.amazon.com/Pro-Quality-20-Piece-Diamond-Point-Rotary-Tool/dp/B000MOI9G6/ref=sr_1_2/191-2787037-3607221?ie=UTF8&s=hi&qid=1284097398&sr=1-2
chuckbeck
