Anybody use a digital readout on a Planer?
Don't know why I am interested, but the digital readout attachment for a planer looks interesting. Anybody using one? Are they accurate? Can you repeat a setting? Plane a board, change the setting, the plane another board that matches the first? Do you like it and would you buy it again? What kind do you have?
I have a lunchbox planer and older Dewalt with the knives I sharpen myself. I generally sneak up on thickness. Often prep stock as thick as it will allow, bringing a set of boards for a panel to the thickest setting the worst piece will allow. Skip plane stuff and then pick the matching pieces and finish planing them. Not so much "plane them all to 3/4" and call it good.
Re: Anybody use a digital readout on a Planer?
I have one....
Tony - Memphis
No, I wouldn't buy another. It works "ok," but it goes through batteries quickly and has to be calibrated and it sometimes sticks and... I'm a nerd and thought it was a neat gadget and it was on sale. The resolution is 0.005" I think. Mine is the Wixley. I have to trick it to get the calibration correct. I still use my dial calipers to check thickness.
Tony
Save your money...
Ken Bellock (Houston, TX)
I have one on my Dewalt 735 planer. I haven't replaced the battery in it since the last one died a while ago. I now just use the stops on the paner to "get close enough" and run all my stock through on the same setting. Wish I could have that money back to put towards something I would actually use...
I like mine...
Grant in Iowa
Hi Barry,
I used to use a DeWalt lunchbox planer and my method of work was run a stack of lumber through, measure one board with a caliper, and repeat to sneak up on my desired dimension.
About five years ago, I found a Delta DC-380 planer for a reasonable price and decided to buy it. I work almost entirely with roughsawn lumber, and I was worried about the longterm durability of the DeWalt in such an evironment, so it made sense to get a larger planer.
I found out almost immediately that the larger planers such as my Delta DC-380 and its clones: Jet, powermatic, and General international all share a common design of using a serrated infeed roller. This roller leaves infeed roller marks on the wood unless you remove at least 1/64"-1/32" or so on the final pass. So you can't plane/measure/plane to remove the last tiny amount in order to hit the thickness dimension you need. You must measure or know the desired dimension, and hit the mark exactly the first time. Frustrated, I would bring the boards to rough dimensions with the larger planer, then go to my DeWalt for the final few passes with caliper in hand to land on the exact dimension I wanted. Down side to this was that I wanted to recapture the capital from the lunchbox planer by selling it, but I needed it to do final thicknessing accurately. Having two planers was also taking up too much space.
I bought the Wixey planer thickness guage and installed it on the DC-380 as shown below.
The first year or so it ate 3 batteries, mostly because I would forget to turn it off after use. I discovered that Wixey had updated the readout design to include an auto-off feature and called them up to inquire about upgrading mine. To my delight, they agreed to send me the updated head for the cost of shipping. I installed that and have been extremely happy ever since. I don't think I have changed the battery in 2-3 years.
It might take a bit of ingenuity to get it installed on your machine, but I didn't find the process too bad. Once you play with the unit a little while, you see what you need to do and it is fairly straight forward to solve the mounting problem.
Once installed on you machine, you run a board through the planer and then place that board between the measuring bar and base and press "calibrate" on the readout and it is set to measure thickness correctly on your machine. From then on, you just run your batch of boards through until you are close and set the machine to the final thickness dimension. No test passes or measuring or getting out the caliper to use the planer. Once calibrated, the readout stays calibrated until the battery dies, or until you bump it hard enough to throw it off. The unit even knows where it is if you crank the planer head while it is turned off, so you needn't recalibrate very often.
I find it is also nice to be able to go back later and hit the exact same thickness for another part. For example, If I am making up a panel and don't like the grain in a given piece, it is no big deal now to make another board exactly the same thickness.
The readout reads to the nearest .005" , which is close enough for woodworking.
As a former machinist, I much appreciate the ability to get a desired thickness without futzing around. It saves time, passes through the planer, and having the calipers laying around.
And I was able to sell the Dewalt lunchbox planer after all.
Regards,
Grant in Iowa
Re: I like mine...
FredD
Thanks for the real life experience Grant , I have off and on thought of getting a Wixey thickness gauge for a Jet 20" planer I have and you have convinced me that it is more then worthwhile.
FredD
Let me add about installing:
Grant in Iowa
The photo in my previous post shows a large vertical piece of aluminum angle that the guage mounts to. That is actually an offcut from a door threshhold plate that I adapted to make a guarded spot for the readout.
I just don't want anyone thinking that piece is included with the Wixey kit.
You will need to use similar found parts to create a mounting method for your application.
FWIW,
Grant in Iowa
Alan in Little Washington (NC)
The early Wixey units had a problem with shortened battery life- Wixey exchanged them for free. The third generation ones (with slanted face) are much better. A new remote readout unit for larger planers soon to be out uses larger AA batteries and supposed to last a year or more (I haven't changed the batteries on my beta unit in over a year). What a lot of folks don't know or forget is that the circuit on these devices is always on, even when the display is turned off- that is so they maintain calibration.
All that being said, I had them on my lunchbox planer, my 15" planer, and now on my 20" planer. Even though the mechanical scale on the 20" planer has an expanded scale that is much more precise than the scale on typical planers, it is still not nearly as accurate or easy to read (with my aging eyes) as a digital unit. I wouldn't have a planer without one.
I put one on a Grizzly 15" and love it
Wayne Carson
I adapted one to my15" Grizzly two years ago and really love it it is right on and if it gets off can be set in less than a min., I had to reset it tonight. Mine is a WIXEY it is easy to make custom brackets to mount to most planes even if they are made for lunchbox ones. If you need a pic of the parts I made let me know and I will email you or anyone else some.
Re: I put one on a Grizzly 15" and love it
Jim Shockey
I put a Wixey on my planer and I love it. I also got the angle Gage for the saw and I got the caliper and am satisfied with all of them.
Re: I like mine...
Grant Wilkinson
To Grant in Iowa from Grant in Ottawa
Is the one that you pictured mounted on the outfeed side of the planer? I have had one on my Dewalt 735 for years, recently upgrading to the new display. It seems to be out by a 64th no matter what I do. Mine is on the infeed side, as the instructions show. I'm thinking that your installation may be better.
Re: I like mine...
Grant in Iowa
HI, Grant.
Mine is indeed on the outfeed side of my planer. I can't imagine it making a difference, however.
I do have to wonder if your planer head might flex enough to cause your 1/64th out of tolerance issue.
Does it always read 1/64th of an inch too thick, or too thin? Seems like if it reads consistently one way or the other, you could come up with a way to fool the calibration step by adding a shim or taking a couple swipes with a hand plane before doing the calibration...
FWIW,
Grant in Iowa
Re: I like mine...
Grant Wilkinson
Grant
The finished piece is always too thin by 1/64". I know that there are ways around this, including simply remembering to plane to a Wixey readout 1/64" thicker than I need. I just don't believe I should need to. It's not a big deal when I am doing all the pieces at the same time. But, I make picture frames and frequently need to mill more rough sawn months after I've done the initial runs. I got the unit so that I could easily duplicate the thickness of the stock before doing the molding processes. I know it's laziness, but I don't like having to remember to add the 1/64" each time.
Re: I like mine...
FredD
Have you asked Wixey about it ?
FredD
Re: I like mine...
FredD
Grant if you havn't read Wixey's FAQ'S on the planer guage, there is a answer about why you might be reading a tad off every time.
FredD
Sale
Tony - Memphis
If you are still interested, I just got an email from Woodcraft and thaey have the Wixley unit on sale for $39.99.
Tony
Digital Planer Scale - Barry
Tony - Memphis
And its Wixey...I keep adding an L in there!
Tony
