Have a question? Ask Woody!
I need some help with staining
Mike Delfuoco
I am building a Pencil Post Bed for my granddaughter
I would like to build it out of Hard Maple. I have
never had much luck staining hard maple and I have
to make sure that the color will match the rest of the
furniture, which is "BLACK", you read it right BLACK
The finish on the furniture looks like a satin finish paint
I tried some black dye on a piece of maple that I had in the
shop and it did not work well
I am now at a loss as to what I should do
NEED YOUR HELP
Re: I need some help with staining
Blue
Try Ebony stain.
Clint Searl
Re: I need some help with staining *LINK*
Clint Searl
If your finish is a drying oil or varnish that will be wiped on, just mix in some dry pigment to the shade desired. If you can spray, make a mix of dry pigment and naptha to wipe on to the desired shade, then spray the top coat. Check out this web site for pigments.
Clint
Pigments
Many years ago when I was in the cabinet business we had to make mirror frames that were black lacquer. We made them of wood suitable for painting (hard maple would be good, but perhaps over kill) Sanded the surface to perfection, painted them flat black and then applied a clear coat of lacquer to whatever gloss level we wanted.
Jerry Samsen
Maybe you can save some money and use poplar rather than maple.
What I have done in the past.
1. Latex primer coat
2. Sand with 180 grit
3. Coat of latex flat paint
4. Sand with 180 grit
5. Coat of latex flat paint
6. Sand with 240 grit
7. Two coats of satin or semi-gloss polyurethane
came out great. My paint was purple not black though (Tween daughter's bedroom color scheme.)
Jerry Samsen
I should have stated that this is obviously not staining. If you need to have some figure show through, then this will not work.
Dick Coers
You could get a base color by using a vinegar/steel wool rust dye. It will chemically react to the tanins in the wood. You could also add a tanin to the maple first. With this method the color is in deep and will wear a lot better. It stays "close" to the wood too, not like a paint.
Brian Boggs technique
it's simpler than you think
Michael Dresdner
Black dye is, technically speaking, not black, and as a result, will not make dense woods, such as maple, black, but rather gray, blue or green. Black pigments work, but most are ground too coarse to get adequately absorbed by dense maple. The one exception is India ink. Waterbased India ink will indeed stain maple black, it's easy to use (simply flood it on liberally, then wipe off the surface) and once it is dry it is compatible under any standard finish.
Re: it's simpler than you think
FredD
This is somewhat like Dres is talking about , that is Black dye is seldom Black by it's self.
I worked with Leather as a hobby that paid well for years and Leather Workers who want a true Black , dye the Leather a dark Blue like Navu Blue first and then the Black dye really is black, works the same on wood.
The Leather dyes like Lincoln, Fiebings and Omega are alcohol based and dry really fast .
A large area might prove diffcult to avoid lap marks , you need to test first.
FredD
