remove bark
remove bark
remove bark
mike mcnerney
I just cut up soome butternut logs, 2 & 3 ft. How do I get the bark off it's on there good. Any worry about bugs, no sign of them now?
Mike McNerney, ottawa
Re: remove bark
Re: remove bark
John Veerkamp
Why do you want to remove the bark? Leave it on while it dries. When you are ready to use the lumber, milling will take care of it. If you're going to turn it, it'll come off when roughing.
John
Re: remove bark
Re: remove bark
del schisler
don't cut into lumber and store. You will find holes. The bugs stay in the bark . I cut some butternut yrs ago. 1982 and this has been stored some with bark on and you can see trail's of eat out and hole's. Now i will use this lumber any way. But it was air dried. If you kiln dry i would guess the bark will come off. If not the heat will kill the bugs.
Re: remove bark
What're you doing with the logs?
The reason to remove the bark is if you're planning to cut the logs through and through and use the natural edges in your projects and you don't plan to do it right away. If you leave the bark on, various wood worms will tunnel through the rich cambium layer and leave tracks on the edges of your slabs.
If you're going to mill the logs into square-edge lumber, I wouldn't bother worrying about the bark.
Ellis Walentine, Host
Re: remove bark
Re: What're you doing with the logs?
mike mcnerney
I am cutting the stuff eventually into lumber & eventual resaw for guitars.
I figured I had to worry about worms or such. the earliest I will be able to cut into lumber is about 2 months from now. So I'm still faced with how do I get the bark off now? Maybe take a skil saw & cut to the depth of the bark, aprox 1" and slowly split it with what I don't know...
Should & what could I spray to keep the bugs at bay. I'm pretty sure it's going to be outside this winter.
In the end it will only be air dried.
MM
Re: remove bark
unwarrented fretting
Bill Tindall
Stop and consider the case of a saw mill with 300,000 bdft of logs on the yard. Do they worry about getting the bark off? No. Why? Because it isn't necessary to do so for any reason until they are ready to saw the logs (and then it is removed to remove saw dulling grit and/or to render the slabs chippable for paper). In fact leaving the bark on will retard surface drying that may check the logs.
The saw mill will remove the bark as part of the milling process.
Re: remove bark
Re: unwarrented fretting
mike mcnerney
thanks all & Bill,
It's good to know I don't have to reallly worry about the bar.
Mike
Re: remove bark
frozen logs
Bill Tindall
You mentioned sawing these logs in a few months. I no longer remember details but I can remember that there could be problems with frozen logs, or perhaps it was partially frozen logs. Someone with more experience with sawing in the frozen north may shed some light on whether you will experience any problems sawing in the winter. Sawing in the winter is certainly done so maybe it is not an issue.
Re: remove bark
mike mcnerney
I shold have mentioned that coating the ends was the first thing I did ( 4 c0ats urethane) and no sign of checking. It's beeen a couple of weeks now . I'm going to get to the resawing sooner rather than later.
I tried hammering the bark off at a ver acute angle & it works pretty easily except I'm over the hill & I can't hammer like I used to because of my wrist & my golf swing, but I digress. The main thing is it doesn't look like I'll get any guitar side out of it because on the longer 3 ft. pieces ther is some old broken off branches that createted some reaction wood. On the other hance it looks like I got a liftime of ukelle stock.
Mike
ps. we don't all live in igloos up here so it will not be 40 below in November & I do't have to deal with frozen logs.
Mike
