mdf uses
mdf uses
mdf uses
Gerald Gibbs
How do I know when the use of mdf is appropriate? I know a full sheet of 3/4 is heavy. I don't know where mdf lies on the continuum from particle board to quality plywood. What is the water resistance after painting? Thanks, Jerry
Re: mdf uses
Re: mdf uses
Jesse Cloud
Hard to answer that question without knowing what specific use you have in mind.
MDF is basically dust and glue, has no grain, but it machines beautifully and will take about any shape your router bit wants it to (unlike particle board). Its very stable and has no movement like real wood does. A properly stored sheet of MDF is close to dead flat. It makes a great substrate for veneer. Its ease of workability makes it ideal for templates and patterns.
On the other hand, get it wet and you have mush. Even with paint, the water resistance is questionable.
If you use it for shelves, you will need to reinforce it with a cleat or a real wood edge treatment, as it likes to sag.
Hope some of this helps....
Re: mdf uses
Re: mdf uses *LINK*
John McGaw
There are highly water-resistant, close to waterproof even, MDFs out there. Even the run-of-the-mill water-resistant sort can be used for exterior trim if it is given a coat of primer and paint and taken care of. The biggest problem seems to be that, even though the stuff exists and is made by at least a few manufacturers, it is nearly impossible to find at your usual cabinetmaker supplier.
I'm not wild about the stuff and used it for jobs like countertop substrate and shop fixtures but when the time came to build 16 feet of floor-to-ceiling bookshelves for my library/gallery/entertaining room MDF and scrap was about what I could afford. I've got to say that once I got used to working with it the results were far beyond my expectations.
One Example of Exterior-Grade MDF
Re: mdf uses
Re: mdf uses
Dave Paine
MDF is off the scale, below particle board. As Jesse commented consider this as a combination of sawdust and glue.
Sad to advise the glue is NOT water proof. Slightest amount of moisture and it will expand and never go back to the original thickness.
MDF is very flat. As Jesse stated great for substrate where it will be covered by real wood.
Paint is not moisture proof. It will crack and allow moisture to contact beneath. It will also allow a small amount of moisture to seep through the paint.
Epoxy may be able to seal the surface, but have to apply a consistent layer.
MDF has almost no strength, so it will sag if used as shelves. It will require real wood/plywood reinforcing.
I have MDF in my shop, but I use for jigs and templates where the pieces will never be exposed to water or moisture. One jig is a Shooting Board for planing edges of pieces of wood. Another is a 90 deg clamping stand for use on the table saw to cut into the ends of long pieces. For such uses, it is an inexpensive solution.
For shelves I use real plywood with solid wood edges glued to the plywood.
Re: mdf uses
Re: mdf uses
Jerry, You have gotten good advice. Let me stress a couple of points. MDF will take excellent detail as in from a router or shaper, but at the same time it can be rather tender and its only takes a little bump to put adient into and edge or corner. For instance, you can make panels for doors out of it and it should do well, butt eh frames need to be wood. Door frames made of MDF will get beat up very quickly.
I just found an old piece of shelving in my shop. I sat some sanding tablets for my Performax on it that were wet from being soaked and cleaned. Basically, It swelled and bulged in a matter of minutes.
I think you will find it sold in sheets that are 49 by 97" to allow trimming the damage off the edges.
Re: mdf uses
Re: mdf uses
Phil Joines
I've made a lot of step stools, rolling tables and shelves, jigs, fixtures and that sort of thing at work.
it's fast to use and as long as the spans are reinforced it's strong enough for most uses. I'm currently making 4 mobile finishing tables 24" x 60" x 34" high. The bases and tops will have 4" tall aprons all the way around that are glued and pinned with 1 1/2" brads. The legs are L shaped pieces using 2 pieces 4" wide and 25" tall. It's all 3/4" stock. They would probably carry 4 or 500 lbs without a problem.It'll take me about 2 days to build and paint them.
Re: mdf uses
Re: mdf uses
Richard McComas
Like all materials MDF has it place and it's limitations. Constructed properly and in the right place MDF can be quite handy for painted projects. MDF paints very well. The picture below is a project made of MDF with hard maple edging and put together with confirmat screws.
The doors have a MDF raised panels with maple stiles. The shelves are MDF with maple edging. All face frame materials are maple. Ever the counter top are MDF with maple edging. The project is now 7-8 years old and holding up well.
With all the crap plywood we get these days the flatness and stability of MDf can be a good product use in the right place. Just my opinion of course.
Re: mdf uses
Nice work Richard!
Marv
Re: mdf uses
Re: mdf uses
Nicholas Tuzzolino
I notice your reference was from the UK. In the states, at least in the west, exterior MDF is referred to as MDO. Used for exterior signs by highway people, etc.
Re: mdf uses
Re: mdf uses
Merle
It is also extremely dust producing. Use a good dust collection system and/or a dust mask.
Re: mdf uses
Are You Sure?
David Yoho
I believe there is an exterior MDF that is supposed to be waterproof, although I haven't come across any and wouldn't think of it as my first choice anyway. On the other hand, there's MDO, which is a plywood with a paper facing that's used largely for exterior signs and interior applications where painting is a concern.
As far as I know, MDF and MDO are different animals no matter where you live.
Re: mdf uses
Re: Are You Sure?
Nicholas Tuzzolino
The MDO you are referring to is what I had in mind. I didn't realize it was a paper coated product. Yes, that is exactly what they use for highway signs, etc. I used a small amount once that someone gave me and it had all the characteristics of MDF, but smoother.
Re: mdf uses
You're right, David
MDO is plywood, made with weather resistant materials and faced with an impregnated paper face that is great as a base for painting. I made a basement door for my barn with just an unpainted skin of 1/2" MDO and it lasted until the barn burned down 20 years later with no signs of degrade.
I don't know that anyone claims to make an exterior MDF -- wouldn't surprise me -- but "water-resistant" MDF has been around for a decade or more. It holds up pretty well, but samples I have been using for years as coasters have swollen everywhere the finish failed. The technology keeps improving, though, and there may be much better products out there right now, but mostly for the furniture and kitchen industries. I don't know how easy they are to buy at retail.
