We value your privacy.
My son has a piece of wood that he brought back from Florida. It has some nice curly figure. Its 2' long and about 7" wide, but has a significant curve.
We want to make veneer out of it, by resawing it on the band saw. He thinks we should make it straight, that is cut off the left and right edges until they are parallel and then resaw it. It looks to me like straightening the board would cut the best curl off it. I think we should resaw it with the curve in it and then use to parts of the board that have the best curl. I'm thinking curved slices of veneer. The veneer would be for the bottom of a breakfast tray for his wife.
You could plane a couple of flats few inches long on the top edge of your picture and then glue a 2ft strip so that you then have a consistent flat surface.
It may be possible to cut as is. Depends on the saw and blade. If the region being cut is above the table, but you do not get undue force downward, then it should be good to proceed.
I would try on scrap piece of same species and similar width to check if the blade cuts true without barreling. I resawed some curly maple and part way through the cut realised the blade was good on the top but way off on the bottom. Turned out the blade was fine for e.g., 1-2in cuts, but too worn for resawing. Changed to new blade and all worked well.
I would probably make a template out of mdf or scrap in the exact size of the tray bottom, then use chalk to mark out the piece on the board. Try a few different positions to get the best figure. Then bandsaw straight lines a bit wide of the chalk outline. Solid wood is a lot easier to cut than veneer, so I would get the piece close to size before resawing.
A sharp blade is a good idea. So is a tall fence, easy to make from scrap. Practice resaws on scrap first to tune up the cut so thickness is consistent from top to bottom.
Good luck. Looking forward to seeing pics of the results!
How good are you with a rip hand saw? If you happen to have a rip saw that is good and sharp, you could do like the old timers did. They would saw from one side then turn the board and saw from the other side. Keep switching back and forth to maintain a straight cut. If you have a planer, use that, if not hand plane the sawed side flat. With a good rip saw, you would have the board ripped in half in less time than it will take to set up to resaw it on your bandsaw.
First, start with the end in mind. You have to previsualize the outcome before you figure out how to get there. The desired result is a [rectangular?] tray, veneered both sides with curved veneers. So what are the options, given that you're starting with this particular piece of wood? Without too much thought, I came up with three possibilities; I'm sure there are lots more.
The sketch on the left is called a slip match, where sequential pieces of veneer are laid up adjacent to each other. The other two are bookmatches. The one in the middle includes a center section that you can fill with another match from this flitch or possibly a different piece of wood entirely, chosen to complement the outside match. The one on the right would be a lot easier and would involve a straight-line rip that maximizes the figure but allows you to have a simple straight seam instead of a curved one.
If you go for a curved seam, the procedure is to make a plywood template of the exact shape and size of your final pieces of veneer, in this case curved on both edges. If you make the curves as arcs of a circle, you will have some leeway in the final alignment, as the pieces will slip by each other without losing the tight seam. The trick is to make the curves complementary, so that when you lay them up, there are no gaps between the veneers. This is a relatively straightforward router jig procedure that I won't go into here because there are a couple good ways and they've been talked about before.
Once you've prepared the template, the next step is trace your template on the board, bandsaw to within 1/16" or so of the final shape, and then pattern-rout the edges precisely to the template. Then do your resaw thing. The hot-glue carriage method is a good one. Don't use more hot glue than you need, or it'll just take more work to remove your carriage later. After you've sawn your veneers, the best way I've found to remove a temporary hot-glued piece like this is to rap it very sharply with a steel hammer in a longitudinal direction. This will cause the glue to shear, probably pulling out some wood fibers in the bargain, but causing less damage than prying it off. Results vary with the species of wood involved.
If you go for something resembling my center sketch, you can use the same template to pattern rout the center medallion. Do it in two steps, using the concave edge of the template.
Marv brings up a good point -- forget the veneer project and just resaw the board into two equal thickness pieces and make a solid tray from those. You can still use the curved template method to join the pieces on a radius if it amuses you.
I also like the solid wood thinking. Should you decide to go that direction, you'll probably only need to re-saw down the middle and dress the pieces to final thickness. The hot glue and carrier board is a good way but here's the same idea with a twist.
Since your board is curved and doesn't have a straight edge to ride the saw's table, and you only need to make one re-saw cut, I'd attach a piece of MDF (mainly because I always have some around for such jobs) to each face of the board equally. The twist is - I would use double-sided carpet tape to attach the carrier boards to the board. This is much easier to take apart but plenty strong enough to hold in this operation.
This method of adding a carrier board not only provides a straight and flat bearing surface to ride on the small table found on most bandsaws but it provides support for both sides of your curved stock while making the cut, making things more stable vertically as well.
