Veritas - Innovation in Tools
Bar hopping.
Bar hopping.
Bar hopping.
Gary Smyth
Last night I put in my �long� homemade crosscut sled which I meticulously fit in April. I proceeded to slide it in the table saw slot when I noticed that the sled was rising to the point that it was getting caterwompus to the blade. I shut it down with no personal damage but substantial damage to the wood runner (groove up the side) and the bottom of the sled. Checking the problem, the cherry wood runner had expanded in the humidity and with my pushing pressure gave it no place to go. With hardly any effort it vacated the slot.
OK. �Enough�, do it right, and last night proceeded to the catalogs for a steel miter gauge slider bar or whatever they are called. What the�. I found only Incra sliders starting at $24 and going to $38. I found some �slippery plastic� that may work. What I didn�t find was a plain 24� to 36� steel miter slot bar. I�m searching for the type on every older miter gauge delivered with Delta/Jet/Sears stuff. Now I understand that it is far more profitable to sell a $100 to $500 �slide table� such as on Jessem, Kreg, Incra, Jet and others, but it ticks me off none the less that the catalogs I viewed didn�t offer just a $6 or $7 dollar straight bar. It seems to me that there is still plenty of profit in a $7 24� �� x 3/8� straight steel bar. I�ve been into Woodworker�s Supply, Woodcraft, Lee Valley, Ebay, Rocklear. None of these people offer just a plain steel bar. I will be hitting the flea markets with a wish list yet again, but has anyone a source for miter slot steel bars for making jigs for the table saw, band saw, router tables, etc?
Re: Bar hopping.
Re: Bar hopping.
Bill Tindall
The misleading title almost caused this busy reader to not open this post.
I used white oak for the "bars" and oriented the grain so as to get the least sideways expansion (growth rings standing perpendicular to plane of table). Works fine in my shop. Don't fit too tight. There is a huge bearing surface for these runners and they don't need to be fit to 0.001". They should slide freely before affixing to sled.
But, any machine shop or metal supply place will have bar stock that a bar can be made from. Try MSC for example, or something local.
Re: Bar hopping.
Re: Bar hopping.
Hank Knight
Plain, oil hardening ground steel flat stock - a basic material - 3/4 X 3/8 X 36" sells for $30 to $40 at MSC Industrial Supply and McMaster Carr. I don't think you're going to find a 24" piece pre-drilled and countersunk for $7, at least not from a commercial distributor.
I've used 3/4 X 3/8 UHMW strips for miter bars with good success. They're a lot cheaper than steel, easier to work and they don't move with humidity changes.
Hank
Re: Bar hopping.
Jim DeLaney, Austintown, Ohio
Re: Bar hopping.
I've used the �" aluminum "Tee-slot" material - sold by nearly all the bigger woodworking vendors. Turn it upside down, and screw it to the sled.
Re: Bar hopping.
Good thoughts all. Thanks.
Gary Smyth
Re: Bar hopping.
Dale Lenz
Keep the runner's/slots waxed good
Dale Lenz
Re: Bar hopping.
Reconsider the Incra's
Dave Bair, Eaton Rapids, MI
They adjust from the top, making it much easier to get a good fit than the regular bars which require you to remove the bar from the slot to adjust.
Re: Bar hopping.
Two things,
Keith Newton----Little Rock, Arkansas
You can roll a bur on a standard wood chisel, and scrape off a couple thou. Just get under good light, and remove the shine.
To roll the bur, sharpen the chisel, then with a burnisher rod, I like to let it roll on the bench top, holding the chisel ~ 45�, letting the rod roll back and forth, as I bring the chisel up to 90�.
After dealing with this same thing many years ago, I switched to plywood for the runners on all of the ones after that. 8 to 10 mm Baltic birch should work fine. I haven't had any problems out of them over 20 years.
Re: Bar hopping.
Re: Bar hopping.
John E in SC
Try e-bay. I have an old Craftsman table saw (yeah I know, but it works for what I do), and it uses a slightly undersized groove. After having the same frustration as you with wood, I went to e-bay and found an old Craftsman miter gauge that I got for pretty cheap. Unscrewed the miter attachment, and used the bar for my sled. Worked like a charm.
Re: Bar hopping.
McMaster Carr...
John in NM
As Hank suggested, but I wouldn't bother with tool steel, just ground flat stock. No point in paying extra for something you're not going to harden, and there's no point in hardening it.
They also sell aluminum and brass if you prefer.
Re: Bar hopping.
Re: Bar hopping. *LINK*
Ken Garlock, Collin County Texas
Good Afternoon Gary.
Let me suggest you take a look at Woodpeckers Inc. They are good people and do have what you need. I have purchased my Incra TS fence and miter gauges from Woodpeckers and have gotten topnotch service.
Their products are made in the USA, even though it is suburban Cleveland. :D
Note that their website is WOODPECK.COM.
Happy sawdust,
Ken
Woodpeckers Inc
Re: Bar hopping.
Re: Bar hopping.
Marv
Gary,
Don't know if you are an eBay kinda guy, but I've found some great buys on various kinds of raw stock. McMasters-Carr and suppliers of that kind charge outrageous prices in comparison.
Marv
Re: Bar hopping.
Jesper, Denmark
Re: Bar hopping.
Jesper, Denmark
Cherry is maybe a little too soft for this purpose? Also, the expansion is not really that much in that narrow width, so take one swipe with a plane to recuce the width and live with the slight slop in the groove - the angular change in the sled from a couple of thou's clearance is not enough to have any significance.
Re: Bar hopping.
Re: Bar hopping.
Brian Aust
Ttrackusa.com has a 18 inch Precision Steel Miter Bar for $15, looks like its pre-drilled.
http://www.ttrackusa.com/miter_gauge.htm
