Performax switch went bad again....
I bought a 16/32 Performax used. Sometime alter the switch got glitchy and finally stopped working. I ordered a new one. Had one of those cute little paddles on it with the piece you can remove to prevent anyone using the tool. I installed it and life was good. Took the old switch apart just to see what was wrong and it was FULL of sawdust. Nothing actually wrong, just so pact with crud it could not work.I tried to put it back together, but apparently I did not have the proper training and skill set and uncharacteristically gave up and threw it away. Took several days for the Pack Rat Gene in me to let the guilt go.
Last night, I pulled out the Performax and NOTHING. Checked the plug, it was live. No juice going through the switch. This one did not glitch out, it just quit. I was using the machine the day before, and then nothing. The switch is several years old. Took it out and took it apart and there was a small amount of crud in it and the contacts were slightly pitted. There were two littler rockers that actually make and break the circuit. Polished the contacts on them with 1500 sand paper. Chucked a pencil in a drill and polished the contacts in the switch body (could not get at them with sand paper.) Blew it out and put it back together and it works. Pretty happy about that.
But, The first switch was a toggle switch and the toggle was looking straight up, basically a funnel for sawdust. The second switch was sealed better and I think the paddle serve to keep some of the sawdust out. It still seems to me to be a location for a better sealed switch. I have had one or two other switches fail but only after long had use and none from getting filled with sawdust.
Is there some sort of contact lubricant I should have put in the switch? Would it have attracted more crud? Wonder if I should find some sort of cover for the switch?
Re: Performax switch went bad again....
Barry about once every other year I have to clean out the switch on my Powermatic saw and more frequently than that the remote switch on my Powermatic lathe. I just went out and purchased a newer industrial grade switch for the lathe. It looks like it's sealed better. On the table saw I assembled it last time with some clear silicone caulk and that was over a year ago so maybe that's helping keep the dust out.
Not sure if that makes me feel better.....
or worse. At least I'm not alone.
I was wondering how much time people spend working on the shop rather than in the shop?
Re: Not sure if that makes me feel better.....
chuckbeck
Too much time is wasted with that crap to be sure. I had to do the same to my Delta TS again the other night. After cleaning the contacts a dab of di-electric grease (those little packs for car battery terminals) helps prevent corrosion and helps to hold those tricky little parts together as you reassemble.
chuckbeck
This was a Double Pole Single Throw Switch so they were switching both the hot and neutral. Don't know why unless they have it set up so that you can convert to 240 if you wanted to. Maybe I should look a the motor to see if its convertible. Actually that probably won't work because it also switches the motor that drives the belt. I wondered about putting some kind of contact paste in it, but I was afraid there would be a cross connection through the paste and short things out and it might accumulate crud even worse.
You would think that by now someone would have a reasonably priced reliable dust proof switch for wood working equipment.
del schisler
i wouldn't worry about. I wondered about putting some kind of contact paste in it, but I was afraid there would be a cross connection through the paste and short things out and it might accumulate crud even worse . No paste will short out ? I would look at buy a different switch from a co. that has a good switch that is sealed. I haven't had any switch problum's with my delta saw's and all my router's 5 of them i use all the time . What i do is blow out all the unit's i use with air tell no dust come's out ? I have at least 7 item's i use every day . I blow out all the motor's and sander's also. I am very pickey. Or just lucky??
