fastening mdf
Jerry Gibbs
I'm trying to make a box out of 3/4 mdf, fastening the ends to each other. What is the best fastener?
fastening mdf
Jerry Gibbs
Re: fastening mdf *LINK*
John McGaw
Does this have to be a pretty, invisible joint? Will unobtrusive fasteners work for you? For invisible joints, corner miters splined with biscuits work ok. If total invisibility is ok then specialized fasteners such as those in the link work a treat. I used these to make a 16-foot wall of bookshelves from MDF and they are rock-solid.
http://www.mcfeelys.com/product/7050-CSP/7mm-x-50mm-Connecting-Cabinet-Screw
BTW
John McGaw
If you use a fastener like this you really need to look into the drilling. It needs to be precise. I was doing so many that I bought the proper stepped drill bit for the job but I guess a really really anal person could manage to do the job a few times with several standard bits, a countersink, and a lot of care.
Confirmat Screws
Stephen
http://www.mcfeelys.com/confirmat-mdf-screws
I am sure those screws are good, BUT
Keith Newton----Little Rock, Arkansas
I just use 1/4" crown 18 ga. staples with glue.
The staples capture a nice bundle of fiber on the top piece, and don't have a tendency to split the second piece like nails or un-drilled screws.
This is much much quicker, and in the end, it is the glue that makes the joint strong. You can bang out twice the amount of work, and after the spackle and painting, nobody knows which was used.
This is not rocket science, and there is no need to pretend that it is.
Re: I am sure those screws are good, BUT
Jerry, you did not say what the box was for or what level of finish and workmanship you wanted, but unless I was making something pretty special, I would not buy special screws that tend to demand a special bit and a special driver to build one box, especially if its some sort of rough and ready shop box or something.
I build a really low stand for my Performax out of some scraps of MDF I had lying around. Its basically a box about two feet square and nine inches tall. (The Performax hides under the wing of the TS when not in use.) As I recall, they were butt joints liberally glued with Titebond and pinned together with Air driven finishing nails. I put an oak band around the top and bottom to serve as bumpers. Those are glued and pinned with brads. Its been rolling around in the shop for about ten years and seems as good and the day it was made. Just last night I turned it up on its end so I could work on the machine.
I might buy some of the really coarse screws they have at the Borgs for particle board and MDF and I might try for a better joint that a butt joint but for a single box I would not be buying a whole new technology in fasteners unless I wanted to anyway.
And I agree that staples would be even better than the nails, if slightly less elegant.
Re: fastening mdf
Andy Lincoln,in Dearborn MI
Jerry,
I have a bunch of confirmat screws leftover from an order along time ago.If you would like say a large handful/small priority box full for the cost of shipping let me know.
Andy
Re: fastening mdf
Jerry Gibbs
Andy- please contact me at gwgibbs2001@yahoo.com. Jerry Gibbs
