Odate's "Geta" in Oct. Popular Woodworking
Bill Tindall
In this article Mr. Odate advocates adding what amounts to a wear strip to the drawer bottom to reduce its wear. But is this a good idea? Wood rubbing on wood will cause wear, that can't be avoided. But it can be moved from one sliding surface to another. In this case adding a wear resistant "geta" to the drawer is going to move the wear from the drawer bottom to what the drawer rides on.
The best plan is to decide what part is easiest to repair when it is worn, the drawer bottom or that which it rides on. Then make the hardest part ot repair the most wear resistant. Drawer wear is trivial to repair. Just plane the bottom edge to a straight line, glue on a strip and plane back to the original size. It is usually vastly more difficult to repair what the drawer rides on.
A case in point is the English cabinetry of the 1800's with its white oak drawer sides and mahogany drawer dividers. Over time the hard white oak mills a groove into the dividers and runner, which can not be easily and attractively repaired.
