Planer positioning
Planer positioning
Planer positioning
I have a problem. My planer is in the way most of the time. My table saw and Router table are the same height so they make sort of a platform. The jointer was set so it's a hair lower than the side table to the table saw so it's not in the way. The planer however is often in the way. It's set high enough right now that I can run long boards over the jointer. It's on a temporary table that I had handy.
I've thought of 2 solutions and don't know which will work the best. One is to mount it on a flip top table. This would allow the planer to flip under the table top and give me a surface the same height as my table saw for a larger work area. The downside is that I would have to make up some sort of spring or counterbalance system to aid in lifting it back up into position.
The other thought was to mount it so the top is below the table saw height so that it would simple be out of the way. The downside is that I would have to bend over to feed wood and I would have to move it more to the side to feed long boards.
There is a 3rd possibility. Put it on a rolling stand with a scissor lift of some king. Then it would store next to the router table and be out of the way. I could roll it out into the open space to the left and behind me in the photo and then raise it up to a comfortable height. This probably wouldn't be any harder to build than the flip top table. Not quite as convenient but then I don't do a lot of planning anymore.
Re: Planer positioning
Re: Planer positioning-Brain Storm
George Colonel's Workshop-Havertown PA
Good Afternoon John,
I like the idea of a rolling table with scissor lift arrangement. I'd consider converting an inexpensive automotive jack, and mount it to a wheeled base beneath the center of the table holding the planer. The planer table could ride within and be stabilized by four vertical pipes/PVC. The pipes could be drilled to accept pins to hold it level and immobile, and at whatever height suited your situation.
George
Funny you should post this. I just spent the day building a base for my planer. I had it mounted on an old base?stand intended for a jointer. (Yard sale Item.) It was too tall. So, I made a base that was slightly larger, but lower. Now it can park "beyond" my band saw and may serve as an outfeed table for it. (My planer has a flat top.) I also increased the size of the casters so that a finishing nail laying on the floor won't stop it any more. My previous base was a closed metal stand. This one is open so I can store stuff under it.
In your case, have you thought about a flip top unit that handles two tools? I was considering putting my grinder on one side and the palmer on the other. If you have another tool that does not get a lot of use that might be a good idea. Something you might not be suing when you need with planer vice versa. The two tools would counter balance each other and make flipping them easier.
Leo Cuellar
Leo Cuellar
Well, John, if you don't use it much, I would put it on wheels so it could be shoved out of the way. I know, I know; WHERE! I have to keep re-arranging for different stuff too. Having a small and/or weird shaped workspace is just plain inconvenient. For a flip top table, I would maybe see if I could cannibalize an old typewriter desk if I could find it free or cheap. :)
Scissors jack
Ray - Middletown, IN
I saw a workbench recently that someone posted a link to that raised and lowered with an old car scissors jack. Might be just the ticket for a seldom used tool.
Ray
Thomas S Stockton
John
I looked at your picture and your comment about not using it much and thought the best choice would be to slip it under the table saw rails on the right side of the saw. My second choice would be buy a cheap hydraulic lift table from harbor freight and use that.
I think the flip table idea would work fine for lighter planers but would be a pain for something heavier like you have.
Tom
Barry I thought about the flip top but that still leaves one tool in the way. When I cut up plywood I lay it on top of the router table and table saw and run my saw between them. I really need a larger platform and having a flat surface where the planer now sits would do the job.
So far I'm leaning toward the scissor jack
I think I can sort of copy the motorcycle lift that HF sells. If I can put the lifts on the sides it would leave some of the middle for storage.
Putting the tool under the right side of the saw is not an option. I barely have enough room over there now, although I've thought about rearranging that part of the shop and putting another router table where the right table saw wing is.
I like the outfeed for the bandsaw. I desperately need an outfeed table for the bandsaw and when I rearrange the workbench side of the shop I will actively consider that option.
Jesper, Denmark
Jesper, Denmark
Hi John,
Although I really have lots of space in my shop it is also a multi-use space, including parking of a car and various yard equipment. All my major tools are on rolling stands, Table saw, Bandsaws, DC 380 planer and DJ 20. The table saw and large bandsaw are arranged so there is room for handling 12 foot boards on both infeed and outfeed sides. They do not often get moved, but can if I need to handle longer stuff.
Everything else is stored along a wall out of the way, and only rolled out when needed.
All my heavy tools are on wheels except the 2 lathes and they have wheels that can be installed. I have the table saw in just about the optimum position right now. I can rip up long boards and fairly wide boards without having to move it, although ripping a 2 foot section off a sheet of plywood is a little dicey, I'm working on that.
The outer portion of the shop is going to get a complete redo. The middle where the table saw is probably won't change unless I move the metal lathe then everything will get changed. I've been waiting for cooler and dryer weather because to do what I really want will require moving things out into the driveway for a few hours or even overnight.
ThomD
I have the Canadian version of this:
http://www.harborfreight.com/catalogsearch/result/?category=&q=lift+table
mine does 660 pounds, and I use it a lot to move heavy metalworking tools. I wouldn't be without it. Currently it is housing my largish granite surface plate.
That said I think a flip table with a granite surface plate (small) would roll your planer, could be home made, and would add a tool to your table.
del schisler
Not cutting down your shop. Don't you have to much in the center? Jointer next to the saw? Mine is on the right side with a small path in between. That way you can edge a board than back to the saw with out going out of the way as You have your's set. As far as the planer goes how about wheele's That is what i have on mine. and not a problum with rolling around when you are planing a board. I have mine where i can roll it and hook up the shop vack line with a blast gate. I have gates on all my equiptment. Look's like i would try and find some wall space and get my equiptment spread out?? Sometine's that can't happen . Depend's on what is the shop used for?? good luck I haven't read the other post's yet
David Hay Denver
In addition to the ideas you've already received, is there a place where you could store it up against the wall? (i.e. what's just to the left of your picture) You could put it on a platform with full extension drawer slides. When you want to use the planer, you pull it out like a drawer. When you're done, you push it back against the wall.
David
Lynn Baker from chilly Glacier WA
FWW a couple of issues ago featured a flip-top planer table which served as an outfeed table for a table saw. it looked easy to use and pretty simple to build. I'm not home now, but if you are interested, I can find the issue number and Email you or send you a scan if you don't have a magazine copy available.
Lynn
Good thought. I have a large granite surface plate that probably outweights my planer. No not probably, definitely. How would you attach it to the surface. I don't think glue would hold. It would probably need a metal framework with would get in the way with sliding things over it.
Lynn I would appreciate knowing where it is. I have every issue or FWW from way back.
Lynn Baker
John,
The Planer flip-top table is in FWW #199 from August 2008. It was a bit further back in time than I thought. It's on page 14 in the "methods of work" section. I hope you can use it.
Lynn
Thanks Lynn I'll look it up tonight.
