DW735 planer
DW735 planer
DW735 planer
Barry Rubenstein
My DW733 planer finally died and I bought a dw735. I made a few cuts and it is super smooth, but I have one problem. It is way too hard to turn the crank to raise/lower the cutterhead. I feel something will break if I turn it too hard.
Anyone have this problem? I'm bout ready to return it. Help!
Re: DW735 planer
Re: DW735 planer
I have had a DW735 for many years. I won't say that it is "easy" to turn the handle - but it is not "difficult". I can lower the cutterhead assembly with one hand - even with a stack of lumber on top of the machine. Come to think of it, I can raise it also.
I would say to return the machine while it is still under warranty. You shouldn't be having this problem.
I will say that after all the years I've had the DW735, the only real "problem" that I have is that the dust shroud inside the cutterhead assembly is poorly designed. The "tabs" for the on the shroud have a tendency to break if you screw down the posts too hard.
Good luck.
Re: DW735 planer
Bart Goldberg
Re: DW735 planer
Bart Goldberg
No- never had the problem. Have you try lubing the screw posts?
Re: DW735 planer
Re: DW735 planer
Warren White
You are probably already aware of this, but just to be sure, you can't raise it above what is set on the turret stop.
Re: DW735 planer
Re: DW735 planer
Mine turns very easily with one hand. No pressure needed at all. As mentioned above, if you have the adjustable stop set it won't go past that. If you have the adjustable stop set for 1/4" and your trying to adjust it at 3/4 or 1" it should move very easily. If not I would return it. Even if it doesn't have any grease it should move without much effort.
I'm very happy with mine. Spent the morning making shaving with it.
Re: DW735 planer
Related question on outfeed tables
Are any of you using these. I feel like I would benefit from them at times but at roughly $50 I don't want to waste the money. Anyone have them, pros, and cons?
Re: DW735 planer
Re: Related question on outfeed tables
I have the infeed and outfeed tables.
Cons - they aren't cheap. They "flop" open when you move the planer to store it. If you wind the cord around the storage "ears", you can't fold up the outfeed table.
Pros - they make a good shelf :D. Seriously though, they do make a difference in snipe. I used my DW735 without the infeed and outfeed tables for several months before I broke down and bought some. The amount of snipe is much less. It makes feeding a bit easier.
Re: DW735 planer
Different Animal-Same Stable
George Colonel's Workshop-Havertown PA
Good Afternoon John,
First, mine is an older #733 and is chugging along just fine. I felt the need to make an auxiliary table, primarily for thicknessing veneer, since the #733 is capricious to crank much below 1/2" in thickness. Itsd hard ernough approaching 3/4", for that matter.
I thought to make the aux table somewhat longer than the steel fold up/down in/outfeed platforms attached to the planer. Thus, it becomes a very nice outfeed table. A cleat on the bottom front of the aux table allows a greater infeed surface while retaining its position within the planer.
I do sacrifice some capability to thickness extremely thick boards. However, the planer capacity is sufficient to accommodate both the aux table and all the lumber I've ever shoved through it these past ten years.
George
Re: DW735 planer
Re: DW735 planer
barry
I'm not sure I understand. The highest stop on the turret stop is 1 1/4" (I think). Do you mean to say that the cutterhead can't be raised higher than that?
Re: DW735 planer
Re: DW735 planer
Warren White
I should have been clearer. The turret is a depth stop, meaning that you can't bring the cutter lower than what is set on the turret.
In other words, if you have it set for, say 3/4 of an inch, you can't dial down below that depth, to say, 1/4 of an inch. You can go up all you want (within reason).
Warren
Re: DW735 planer
Re: Different Animal-Same Stable
I also have the older model Dewalt, the one that has the knives you can sharpen. Mine came with folding infeed and out feed tables. Then I added the dust collection hood and you can't fold the out feed one any more. I have never used mine without them, but I can imagine it would do as good a job.
But, Like the Colonel, I have added an auxiliary table from time to time. I would suggest a piece of melamine coated material or a piece with plastic laminate on it (both sides for balance.) Make it about 2 1/2' or 3' long and put a cleat under it to keep it in place with about the same in feed as outfeed. Needs to be nice and flat and slick. I agree with the Colonel abut the thickness also. If you run into a really thick piece of wood, you can remove it long enough to plane it. You don't even need tools. Would not work well with that flip top thing I suggested above unless you fastened better.
Re: DW735 planer
Re: DW735 planer
I would go to a store that has one and try it. Or maybe a Friend has one you could compare it to.
Don't want to be obvious, but mine has a cutter head lock. It's really stiff If I try to adjust it while locked. Yours is not locked is it?
It appears your's is new. I might oil the posts, but not much more than that. If it is really stiff and not something really simple, I would take it back.
Re: DW735 planer
I just got my 10% birthday discount from Woodcraft and I'm going to have to drive within 2 miles of one on the 10th so I guess I'll shell out the money. I get very little snipe on this machine but thought they might help. Mostly I think it will make feeding longer stock easier.
Re: DW735 planer
Depth Stop?
Tony - Memphis
I forget sometimes that I have the depth stop set and I end up trying to go past it!
Tony
Re: DW735 planer
Re: Checking The Cutter Head Lock...
David Hay Denver
...was my first reaction as well.
