help needed, finishing Morris Chair
Roy Anderson
Had the great experience of making a Morris chair at Dale Barnard's shop this past month. Now I have to finish it out.
Looking for ideas. I don't want to fume it but I want a finish that looks like that. Dale and I discussed various stains and glazing stains, but I'd like some input here.
I spent a lot of time, sweat and money making this chair, and I don't want to blow it on the finish.
Also, I need to get the upholstery done. Anyone who can recommend an experienced Morris Chair upholsterer in the Cincinnati area, please speak up.
Re: help needed, finishing Morris Chair
sure fire way to not screw it up.......
bill tindall
....Get it right on test panels first.
I would think the best advice would be from the place where you made it.
Not at all clear why you want it to look fumed but don't want to fume it. Fuming would seem to me to be the most fool proof means of coloring one could use.
Fred Davis
After reading Jeff Jewitt's treatise on a six step stain, why would you not want to fume it , since you say that's the look you want.
Hard to screw up a fuming process and one only needs to watch the color deepen to get the effect you want.
FredD
Merle
I have fumed using regular house hold ammonia. I think the color comes out the same as using industrial ammonia, but perhaps it doesn't penetrate as deeply into the wood. I haven't sawed into a finished piece to check. :D
To those who asked:
Roy Anderson
I'm reluctant to fume the chair because
The gel stain process leaves an antiqued look by darkening in the crevices and joints.
I don't have a tent for fuming so I'd have to make one.
I live in a crowded neighborhood with neighbors who would probably have a panic attack if they got a whiff of ammonia.
My workshop is in my basement, so I'd have to do it outside on my patio.
ammonia is not to be feared
bill tindall
There have been posts here and elsewhere fretting over ammonia exposure. One is not going to be any more exposed to ammonia fumes fuming a piece of furniture than would be the case cleaning the inside of a car window ( or other cleaning chores) with ammonia, which I do with regularity. In days past if you fainted a dollop of ammonia would be thrust under your nose to wake you up. The fumes in any concentration are so obnoxious that you will avoid a hazardous concentration. The few times I have fumed, it has been inside a plastic bag in the laundry room, where the ammonia bottle lives.
Preparing a crude frame over which a plastic tent is fashioned would be vastly less effort then making the chair-which looks to be nice.
I don't know how well household ammonia works and this could be a reason to use a pigment stain. I use the concentrated lab stuff. Heating the household stuff will get the vapor level up if you can't round up something more concentrated.
That said, the color produced is not as light fast as a mineral pigment stain.
not to worry
bill tindall
I can not think of any reason the color would be less deep if the intensity was the same.
Fuming and Stickley finishing
I've done quite a bit of fuming of oak (English, white, others) over the years, and here's what I've experienced:
Fuming wood with ammonia
First, if you're going to use blueprint ammonia (28% concentration), DON'T BREATHE ANY OF THE FUMES AT ALL! I don't usually shout, but one of my helpers got a whiff of the concentrated stuff once and we thought we'd have to take him to the emergency room. He got over it, but it was pretty scary for a while. The fumes just seize your lungs in an instant.
Household ammonia (5% concentration) works fine for fuming, though it takes longer because the vapor pressure in the tent is that much less concentrated. It will penetrate just as deeply if you leave it in there long enough; I usually swapped out the ammonia after 12 hours or so to keep the vapors up. Make sure your wood is up on blocks or painters triangles (tetrahedra?) and that the tent material doesn't contact it. I used thin strips of wood perched on the top of the item to hold the tent at bay.
Fuming is a progressive effect that you can monitor by chopping off pieces of a test stick at timed intervals. I recommend you prepare a test stick, say 1x2x12 or so, sanded just like your project, and put it in the tent with your chair. The effect begins immediately and penetrates deeper into the wood as time goes on. With household ammonia on English brown oak, I found that overnight is plenty of time. American white oak (and European white oak, if that's what you're using) is lighter in color to begin with and takes longer to darken, but it gets there eventually. I never had much luck with red oak, cherry or mahogany, but they all take some color from the fuming.
The actual outside color of the wood changes to a medium silver gray in the first half hour or so and deepens only slightly after that, so don't expect to see continually deepening colors or a lot of rich browns. Those come only after you apply a finish.
I've made very successful fuming tents out of 6mil polyethylene sheet, held together with duct tape and sealed to the floor or assembly table with foam tape, though you can also just use duct tape. If you've sealed the seams of your tent well, you shouldn't have any serious escape issues.
Another thing to be aware of is that fuming raises the grain of the wood. My procedure was to first wipe the wood down with water and let it dry, then sand set the piece very lightly with 320-grit sandpaper to smooth off any raised fibers; then, I would put the piece on the table or floor and cover it with the tent, leaving one side unsealed. I put one or two 8" Pyrex pie dishes on the floor of the enclosure, filled them half full of the ammonia solution, and closed the flap. You want ammonia dishes with large surface area to encourage the evaporation of the fumes into the enclosure, and you want to use glass because alkalis will react with aluminum tins, not that this is a serious concern with the household stuff.
I used a portable fan to blow away any stray fumes when filling the ammonia dishes and never had any problems, even with blueprint ammonia, but I was extremely careful with the concentrated stuff for reasons discussed above. I'm not sure that organic vapor respirator cartridges even work for ammonia, but I'll bet someone here can fill me in.
While the piece is fuming, you can take your test stick out occasionally and whack a little piece off one end to see how the penetration is going. You can also wipe a little varnish on the test chip to see how the finish color is looking, or even pad a little stain on there to enhance and tone the fumed effect prior to the varnish test.
Stickley finishing
I did a lot of research on Stickley's methods for finishing his Craftsman-style furniture. One thing I learned is that he was an opportunist and an intrepid experimenter -- an opportunist because he used anything that worked and an experimenter because he went through a lot of trial-and-error finishing regimes to try to produce the desired results, which themselves seemed to be moving targets most of the time.
Fuming with ammonia was definitely something Stickley did to his pieces, but it was rarely the only coloring step prior to finishing. Fuming alone, when finished with an oil-based finish, yields a rich brown color on white or English oak. I call it brown-brown, as opposed to red-brown (cherry, mahogany) or purplish-brown (walnut). Fuming has the added effect of darkening the medullary rays, which are often quite pronounced -- they can sometimes be quite garish and hard to compose in a piece without great attention -- in the white oak family. This darkening has a muting effect on the overall piece. After fuming, he often used dye stains to tone the color away from the brown-brown look, which can be somewhat cool to the eye.
Stickley lived at a transitional time in the history of finishes, as traditional spirit varnishes were giving way slowly to more modern lacquers and varnishes. One of the early lacquers Stickley used was made of gun cotton and amyl acetate. He called it "banana liquid" or "banana lacquer" because of its characteristic banana smell. It was very volatile, went on hard and thin, and dried very quickly. The dried lacquer surface was dust free because of the fast flash time, and very smooth, even slippery, to the touch. Modern nitrocellulose lacquers and more sophisticated finishes offer more protection from moisture and degrade.
The upshot of this is that fuming isn't scary, but it can be dangerous if you're not careful. Your chair might look fine with just fuming, but I would encourage you to make several tests and try to come up with a combination of stains that work for you. I have seen Jeff's stain-based Stickley finish and it is quite rich and handsome, and, as we all know, you can't ever be too rich or too handsome. But I have seen a lot of Stickley furniture that looks quite different from Jeff's treatment, too. For that matter, I don't think the modern-day Stickley pieces are much like the originals. If you are after authentic, you'd better go see some original pieces to get an idea of the range of hues and surface qualities that characterize original Craftsman furniture. Personally, I prefer a richer, deeper look, but I usually achieve it with a combination of fumes to mute the rays and stains to modulate the hues. Pigment stains may also be used to accentuate the pore structure and give that "antiqued" or glazed look, which you may also like.
Please keep us posted on what you decide to do and how it works out.
Roy Anderson
This is very close to what Dale recommended. This is probably the way I will go.
Thanks for all the ideas, now ---
Roy Anderson
I need suggestions about the upholstery.
Easy
Go to any respectable upholsterer and show him a picture of what you want. Let him measure the chair so the responsibility for dimensions is his, and pick out the leather or other upholstery you want. Be sure to anticipate how the back cushion relates to the seat cushion. Otherwise, you may end up with a back cushion that doesn't go all the way to the top.
Clint Searl
Your work deserves the best
Clint Searl
Spring down cushions in leather or UltraSuade by a real pro. Indian rug cover would look great, too.
Clint
craigd
Re: Fuming and Stickley finishing
craigd
If you wait long enough, you'll get the deep deep browns. I have a chuck of white oak sitting in a zip lock bag with some house hold ammonia (well over a month now) and it did stay silver for several weeks but now it is deep brown.
Moses Yoder
Ammonia and Meth
Moses Yoder
Speaking of catching a whiff of ammonia, we have a state police officer in our church who says if you smell ammonia you are probably near a meth lab ;) So you may want to warn any nearby neighbors before fuming furniture.
Re: help needed, finishing Morris Chair *LINK*
Bob Lang
Dale knows his stuff, and I doubt if you could go wrong following his advice. Whatever you do, prepare some pieces of scrap the same way you prepared the chair, and go through the entire process you decide to use on scrap first. This is especially important if you use a multi-step finish. With some of the processes, it can look like you've ruined the finish after the first or second step.
The safety recommendations for working with ammonia are worth repeating. In addition to protecting your lungs (there is a respirator cartridge approved for ammonia), you should also protect your eyes with goggles, and your skin with rubber gloves. The other issue with fuming is that there is no guarantee that the entire piece will come out the same color. The flakes and other parts of any given board will color consistently, but different boards may not. If you include any sapwood (easy to do) you'll need to add and blend color to portions of the work. Here is a blog post about fuming and touching up the color if you're so inclined. PopWoodBlogPost
Jeff Jewitt's method looks really good, but it seems overly complicated to me. The main thing for an authentic look is that you don't want the rays to pop. They should be subdued and about the same color as everything else. Generally speaking, this is done with a combination of things that add color in different ways to different parts of the wood, or tone the entire piece. Fuming alone won't get you there. It doesn't look right until you add shellac (any flavor except clear) and some dark wax.
While I believe that a fumed finish has a distinctive look that can't be duplicated by any other means, you can come very, very close with several different methods. The link below is to another blog post with the easiest way I have found.
Bob Lang
WoodWorking Magazine Simple Finish
........or a chicken house or sheep pen
bill tindall
Chickens poop urea which hydrolyzes to ammonia when wet. Ditto sheep pee. The ammonia odor when mucking out a sheep pen is stronger than I have ever smelled from my limited fuming attempts. "Arts and Crafts" gates and corals anyone?
Fuming the Bank
bill tindall
In George Frank's entertaining and informative book, Adventures in Wood Finishing, he talks about a bank project where the wrong stain had been applied and the entire bank trim was too light. They taped up the bank, set pans of ammonium hydroxide about the bank with heaters to volatilize the ammonia and waited until the wood had darkened to the proper shade.
Wow, that's news, Craig. Thanks.
Re: Fuming the Bank
I fumed a white oak kitchen that way back in the 70s. The owner couldn't believe it, but it came out pretty good, considering the relatively low concentration of vapors.
Re: Fuming the Bank
FredD
That was George's idea and it got him promoted, always liked his version then of nail hole filler , well chewed French Bread/
FredD
Charles Jackson III
Thats a nice job on the morris chair.
