HELP looking for a pullu assy.
wayne
I have a Boyce Crant table saw with a pully assy. and I want to put a larger motor on the saw. A 3hp 120v is to big a frame so I need to put a 220 3 or 5hp. Problem is the shaft is 1 1/8" and this pully assy is for a 5/8" shaft. The motor doesn't move with the trunion but the pully moves on the shaft. Any ides what the contraption is called or where I could find one with a larger shaft hole. I need a heck alot this gets confusing for such an easy thing. [uplimg]/webbbs/media/temp/77da20008714b7729b3221e4c64c7cf4_1_pully1.jpg[/uplimg] [uplimg]/webbbs/media/temp/77da20008714b7729b3221e4c64c7cf4_2_pully2.jpg[/uplimg]
Re: HELP looking for a pullu assy.
Hopefully picks.
Wayne Carson
Virgil Johnson
Are there any manufacturers name or number on the part you need to replace?
NOT A THING on them
Wayne Carson
Re: HELP looking for a pullu assy. *LINK*
Roy Anderson
You may be able to find what you need here.
McMaster Carr pulley info
Tom Dunlap
Any large city, and lots of smaller towns, have stores that handle sheaves like this. Look for a Graingers at a minimum. You'll need some sort of business ID to buy but that is a facade. Find a pulley or driveline vendor.
Grainger doesnt have any
Wayne Carson
The problem is that the pully has to slide on the shaft. The pully has ball bearings between it and the shaft it moves laterially along the shaft in order fot the miter to work.
Ask over at OWWM.COM
Hank Knight
Unusual to say the least...
John in NM
Undoubtedly a proprietary part that Boyce Crane made themselves for use on those saws. If you're lucky you may be able to find one for a bigger saw of the same design, though finding parts for old machines can take decades - the junk ones that are available for parts tend to sit ignored in corners and out in fields and scrap yards, and there are few vendors that specialize in taking them apart and selling useful bits.
If you have machining skills you could perhaps fabricate something similar, linear bearings are cheap and readily available these days. You may be better off living with the motor you have or finding another old saw with a bigger motor. I'd love to find an off the shelf gear box for my WT bandsaw, but its just not going to happen.
