Small shop vac?
Small shop vac?
Small shop vac?
doug f, san clemente, ca
I'm looking for a small shop vac to dedicate to a single band saw. It should have the following:
Wall hung
2 1/2" hose
1-3 gallon
Good vacuum power
Under $100
I've spent a bunch of time on the internet but can't seem to find the right combination of search words to find what I want, so I'm asking my "go to" source. If I can find the right model, I'll even look at used ones.
Any suggestions?
As usual, thanks for the help.
Doug
Re: Small shop vac?
Re: Small shop vac?
Dave Paine
A number of shop vac's available which are hangable. Quick search at Sear's and Amazon will show them. Price''s in your range.
However the small size you want means that hose size likely to be 1 1/4in which may result in airflow being too low. These units are typically loud.
Re: Small shop vac?
Thanks, Dave.
I've looked at Amazon, Sears, even the Shop Vac site. You're right, my biggest problem is the small vacs all have 1 1/4" hoses and yes, that would be too small.
I'm beginning to think what I'm looking for doesn't exist.
Thanks for the suggestion.
Doug
Re: Small shop vac?
Re: Small shop vac?
paul in AZ
You might look at Harbor Freight's 13 gallon 1HP dust collector. It takes a 4" hose but I think it includes a step down fitting to shop vac size hose. If not, places like Woodcraft have the step down connectors. It lists at $120 but the cashiers usually have extra 20% off coupons if you ask them. I use one on my bandsaw. Not world class power but it does the job, is very compact and is wonderfully quiet. Who knows how long it will last but at that price...???
Re: Small shop vac?
Re: Small shop vac?
Some of the hose ends for the smaller diameter hoses are actually 2 1/2". I have a Shop Vac with the smaller diameter hose. I will sometimes switch hoses for a 2 1/2" hose. I don't know if I would recommend it with a smaller vacuum though (I'm doing this with a large Shop Vac) - it may not be able to handle the extra air flow.
