Glue bond question
Glue bond question
Glue bond question
Gary Smyth
I have a piece of 1/2 birch plywood from which I'm making a top for a piece of bang around porch furniture. The edges of the ply will have a solid wood contrasting edge mitered at the corners and flush with the top and bottom of the ply. i intend to glue the solid wood to the ply. Now which would be stronger? Would gluing to a plain sawed edge or gluing to a sealed edge give a better bond? If I use the plain edge my thought is that the glue will be absorbed into the edge and might make the glue up weaker. On the other hand would a sealed edge prohibit the glue from making the stronger bond with the ply? I know that it will work either way, and for this piece it won't matter, but for the future and better projects to come, it might make a difference.
Re: Glue bond question
I don't know the answer. Try an experiment. Make up some set pieces and check for yourself. There are many variables. what would the chemistry of the bod be with different sealers? Is the bond strength of the sealer to the wood and the bond of the glue tot eh sealer stronger than just glue? I would try Shellac, except it might not be the best thing out doors.
Personally, I would glue size the edge or the plywood with Titebond and then glue the edge banding to it with Titebond. I might go to titebond II or Maybe III, but that is probably unnecessary. Titebond is probably as water proof as the plywood.
Marv
I would use Epoxy and not seal the edge.
Marv
Gary You will have very little long grain to long grain glue joint in this type of joint. I would recommend epoxy if you insist on this joint. I would make some sort of joint with more glue surface, especially long grain wood. Cut a groove in the plywood and make tongue on the outer wood. This will give you a much better bond.
FredD
Unless you want a wider strip of solid Birch showing , in the past I have cut a Vee groove in the panel edge and cut a strip of solid wood with a 45 degree angle on each long edge and glue that in. Of course you would miter the joints.
Depending on how wide the edge band is , you can make the plywood look like solid wood.
FredD
Jesper, Denmark
Jesper, Denmark
IMHO, no sealing of the edge, as it will become the limiting factor in the bond strength.
As others have suggested, some sort of key in the edge and the solid wood will add strength and make it easier to clamp up. T+G or biscuits are not so easy in only � inch ply. If the design allows it, you might consider maing the frame thicker and cut a rabbet in the fram you can lay the ply into.
I have a router bit "kit" for edging plywood. It cuts a "V" in the plywood and the corresponding inverse "V" in hardwood.
I have used it for edging many a shelf. I have always just glued the hardwood to the plywood. I have yet to have the edging come loose in either my shop shelves or many book shelves that I have built for myself and others. I usually use Titebond.
PS, Now that I have read....
What everyone else posted, I agree this would benefit from some sort of joint that increases the surface area for the glue. The vee Groove approach or the T & G Idea, or even a spline. The problem is that all of those require some sort of set up and perhaps a new tool or set of bits. This could be either "Happy Birthday, I get a new toy." or "Rat's I don't want one and will never use it again."
Another approach might be veneer tape. You can buy matching veneer tape that you press on with an iron. Back in the day, I put about a mile of it on a set of walnut plywood cabinets that had flat panel doors. You can also make your own. Just rip some very thin strip and glue them on. You can even try putting glue on both the panel and the strip, letting it dry and pressing it on with an iron or just clamp it on with a set of straight calls. You can buy a little trimmer to clean up the edges, do it with a flush trim bit in a router, or do it with a knife or even a rasp.
Re: PS, Now that I have read....
FredD
Regarding the Vee groove as I do it Barry , all you need is a table saw, unless of course your a hand tool fanatic ;-))
FredD
