OT 27 Square of siding and I am
Dustmaker Mike
So here goes the finial tally
27 Squares of siding autumn red
18 outside corners
10 inside corners
lots of brick mold
lots of J channel
lots of F channel
Vented and non vented soffit
lots of fascia
Lots of caulk
Lots of nails
Lots of flashing
and the house and shop are not done. I ran out of siding. I missed by two pieces and now I have to wait two weeks for them to come in because it was a special order. Now I bet I have to buy at least a SQ to finish just because I don't want to piece the last little section with a bunch of odd sizes.
Oh well Life Goes On.
Re: OT 27 Square of siding and I am
Soooooooo close
Don Orr
Now you have some extra time to work on the shop. :D
David Hay Denver
Bummer. Well, look at it this way, at least you'll have some extra material in case any of the siding gets damaged somewhere down the road...
David
Another example of a basic rule
for any given project, you will suffer one or both of these problems:
1. Not enough material. This occurs most often for items that must be special-ordered and/or color-matched.
2. Way, way, too much of a given material. This generally occurs for things that are so easily acquired that they have no resale value and are too much of a hassle to return; or are very hard to store; or all of these.
If you're really good at your work, you can usually avoid problem #1 by always going straight to problem #2. This is more expensive (to WAY more expensive), but gets the job done. You will waste less time in the building work, thus saving time that you can waste in figuring out what to do with the leftovers.
If there's a Habitat for Humanity ReStore in your community, you can often resolve the leftovers problem by donating them to Habitat. This doesn't solve the "expensive" part of the problem, but does feel good.
