OT Folding maps
OT Folding maps
OT Folding maps
woodenleg
I have used maps that were laminated but folded in a way that made it easy to carry and use. Is there a special way to laminate or some place you can send the map and the company will do it. I' m going riding in the woods on my ATV and want to have good maps. The maps are real thin.
Dave
Re: OT Folding maps
Re: OT Folding maps
Tom Dunlap
An inexpensive laminate is clear Contact Paper. You can cut the map into smaller chunks to make it easier. Laminating back to back sections works too.
Leave about a 1" border and trim it down if you need to. Practice with scrap paper or junk maps so that you get how to lay the paper onto the Contact Paper. I've taped the CP down so that the static charge doesn't make it jump up to the map. Another trick is to peel back the corner of the CP and then lay down the map as you go. This way there is little extra sticky side to grab the map and make a wrinkle. Go slow, you don't get Do-Overs!
When I do that for USGS maps I take the time to use darker pens for trails, water and other features that I want to find. Adding declination lines and section lines helps too.
Most copy and map stores will laminate too.
Re: OT Folding maps
Re: OT Folding maps
Marv
Wood,
You probably need a way to carry the maps so they don't get wet. I'm thinking a round tube with a cap on it, maybe one of those shipping tubes you can buy at the post office or a stationary store. Attach the tube to your ATV some way so it is safe and easy to get to.
Have fun,
Marv
Re: OT Folding maps
Re: OT Folding maps
bill tindall
It is not clear whether you already have the maps and want then laminated in some special way, just laminated in which case take them to most copy stores or shipping stores, or whether you want to wind up with water resistant maps that you will buy.
One can download for free topo maps and then print them on water resistant paper, or you can order them for a fee already on water resistant paper.
Respect private property for some land owners don't like to have their forests tore up by ATV trespassers. I have a dim view of the ATV crowd in my area for they continue to use the logging roads I am trying to stabilize against erosion.
Re: OT Folding maps
Re: OT Folding maps
woodenleg
Bill, I am riding on USFS trails for ATV's, no private in the area I'm in but I understand what you are talking about, I have been shut out of hunting area's because people won't respect the land and the landowner. The maps are USFS and are really thin four folds and you have the start of a tear. Dave
Re: OT Folding maps
I don' mean to change the subject
Gary Smyth
but why not get a gps and forget the map thing entirely. With a map you guess with a decent GPS you are within ten feet and you can get back points, altitude, distances, and most anything else of importance. I'm told that you can get or soon will be able to get a ELT Emergency Locator Transmitter for the GPS that can alert others if you get in trouble. I love maps, but for the boonies I'm a convert to GPS.
Re: OT Folding maps
Power tools
Tom Dunlap
If you don't know how to use a map and compass what good is a GPS without power?
If you're going somewhere and relying on an electronic beacon and then the rescue system to take care of you you shouldn't be there in the first place.
No different than woodworking...if you can't cut straight with a handsaw you're not likely to do better with power saws.
Re: OT Folding maps
Re: Power tools
Steve Schoene
I agree. Strongly.
GPS units are handy and fun, but they should never replace having an actual map and compass, and a little care in locating your position on the map every so often, so that when the electronics fails you still can find your way. Belt and suspenders--mayhaps, but knowing where you are is a lot more important than keeping trousers up.
Re: OT Folding maps
Re: I don' mean to change the subject
woodenleg
I am going to be using a GPS but the map shows what trail or road I can ride on. There are some of the roads that you can only ride on for a short while, First time I have ridden in the area, so therefore the map. Dave
Re: OT Folding maps
Relying on technology for rescue *LINK*
Tom Dunlap
I found the article about rescue beacons and related issues.
Too much technology not enough skills
Re: OT Folding maps
They just keep on making fools, don't they?
Re: OT Folding maps
Are they charging them?
Phil Joines
They should have to pay for being "rescued". Why should our tax money go to support fools?
