Hook & Loop abrasive paper
Robert R. Clough - Thorncraft
Does anyone know of standard sized sheets of abrasive paper with h & l backing? Obviously various grits. I checked Klingspor and found only expensive rolls. I use my Dremel Maxi a lot and find the abrasive paper made by them to be expensive over time.
Re: Hook & Loop abrasive paper
I believe you can buy 1 meter wide pieces from Industrial Abrasives. A square Meter would produce so many Dremel pieces you would have to buy a Dremel for each grit.
Glenn Madsen near San Francisco
Klingspor has a retail shop with a catalog and an online presence of sorts. They sell boxes of bulk abrasives, trims from all sorts of stuff, by the pound. Turners love it, because for a modest price, you get five or ten or twenty pounds of stuff. One box you can buy is hook and loop. And I did, about 5 years back, for the sanding tools I used on the lathe work. The box is still at least 2/3 full. Multiple grits. Less than $20, iirc. I spent that much on sanding disks at the Borg this week, two grits.
