Band saw Barreling Question.
Tryed to resaw a piece of really curly walnut root today. Used a 14" delta bandsaqw iwth a riser block. Teh piece was aobut 6 1/2" wide and 5/8" thick. Set up my new Kreg fence with point guide and tried for a slice about .1" thick, planing on four slices. Made a couple of practice cuts first on palin walnut. Took the first slice off the root and the balde curved inside the stock toward the outside about a 1/4". I think its called "barreling". It was a half inch 3 tpi hook tooth blade and while not new, it seemed to be in good shape. I have an improved spring from Ittura and the tension was set at half inch. So, what is the problem?
What did I miss? New blade? More tention?
And, does it ever barrel the other way, toward the fence?
Re: Band saw Barreling Question.
del schisler
my guess new blade. Mine is doing the same thing. I have used the blade for a lot of resaw. So a new blade is about to be ordered. I use the wood slicer from highland woodworking. 3tpi 1/2" Works for me . Of course their are a couple more out their that are good. Just i have been using the slicer for a few yrs. I guess if i had a offer to try their's I would do so. good luck on the resaw. I hate when it curves off. Now the planer oh well do what you have to do
Dulling on one side,
Keith Newton----Little Rock, Arkansas
is probably the worse cause of this. Being a root, maybe you hit some grit on one side. It would then tend to vier toward the sharp side.
You could get this in a wood like yellow pine, where there are hard and soft rings, where the blade is just starting to dull, or too little tension, or both. A thin blade is naturally looking for the path of least resistance.
"lead" net set right
bill tindall
I get that when that to be resawed is pointing some different way from what the blade wants to saw it.
Also too small teeth but with 3 tpi that isn't your problem.
