reading your boards-how to tell curly
bill tindall
While it is obvious when finished lumber is curly it is increasingly more difficult to determine this state as one moves back in processing toward the tree from whence the lumber came.. If there is a way to know if a tree contains curly lumber I don't know how to do it. I cut a huge maple once and didn't realize its figure until it was notched for felling.
There is a tell tale sign that a board is curly that can be detected even if the board is stacked in a pile , so long as its edge is visible. Saw mill saws are rip saws with chisel teeth just like a rip blade for a table saw. They are designed to chisel their way through the end grain of a log. When sawing a curly log these teeth encounter grain at orientations other than perpendicular to the chisel tooth. Unlike a cross cut saw these teeth are not designed to slice through the wet wood grain, and as a result they tear the grain instead of slicing it. The result is a fuzzy looking cut.
The bottom board in the picture shows a typical cut. One can see the cut made by each tooth as it passed through the log. While overall the cut is rough from irregularities among the teeth, each tooth is individually leaving a relatively smooth cut. In contrast, the fuzzy surface on the top board is the result of a cut through a curly log. The fuzz is torn grain ripped out of the log by the rip teeth in places where the grain was not oriented along the length of the log. .
So, If you are looking for curly lumber in a lumber stack, seek out fuzzy surfaced lumber.
