We value your privacy.
JL's thread got me thinking. The previous owner of my house removed the front porch stairs and boarded over the opening. She chain-link fenced the house in. There are three steps on the side of the porch.
Looked like a stockade!
I have removed the chain-link fence, ripped out and redesigned the porch railing (not up yet) and I need to replace the stairs. Have no idea what was here before.
Arizona hot sun. Snow in the winter, monsoon rains in the late summer. Wood dries out very quickly. Finishes are at best an annual maintenance job.
Suggestions for design, materials and finishes (or not)? Height is 47" for what that's worth. Lot has no grass, indigenous grasses and flowers, and tall Ponderosa pine trees. There are some lower cedar type bushes along the front of the porch, except for the stair opening. Porch is entire width of the front of the house. House faces west.
I vote for stone - you've got enough of that around AZ.
Pick a comfortable rise - 7-7 1/2". For an exterior stairs, I like a run of about 11" - but that's me. I don't know what is code in your area. Figure on at least 10".
If they are sitting and perching steps - I like a greater run. It also makes it easier to get things onto and off of a porch.
While everyone likes 61/2 to 7 in rise for steps, think about how long you are going to live there, as you get older it is harder to climb steps with the normal riser height. If you have the room go with a longer run and smaller rise in the steps. Also you need to think about how you are going to clean the steps with snow or ice on them. Everything gets slick with mother natures help, put in steps that can put up with what you use to clean those steps in the winter. I have seen just about everything for steps and with a wooden leg everything is an interesting climb, the best thing that I have seen but looks ugly is steel grates mounted on ps stringers. Last a long time and is easy to clean in winter. Have fun, Dave
And if your back acts up again you will like it also. Yeah it's an extra step but worth it. Might think about paint with sand added for traction, or maybe a truck bed liner paint. That should be durable and have good traction.
Lots of Coconino sandstone from your area gets sold all over as paving flag stone, its that nice pinkish very gritty sandstone you see in landscaping yards. Cuts easily with an angle grinder and dry cut diamond blade, mortar down to concrete steps with regular brick mortar or tile thinset if you like.
Like JL, I prefer 7-11 for rise-run, too short or too deep and I find the stair awkward. It's also easy to remember
That's a look like I think I would like. Thanks, John.
But it may overwhelm the porch with it's mass.
So, maybe stone stringers (over concrete block) and Trex treads with hitching post rails, curved into a wider base than the top.
On the rise, I am with Ray. My knees don't do steps well. I'm thinking 5-6".
I might even ask the county what they would like. Though I don't expect them to use the stairs. I don't expect them to even stop by to say "howdy." 'Course, I didn't invite them either.
7" is never the minimum, in fact, in commercial settings it is likely to be the maximum. I don't think the IRC residential code has a minimum. though I have seen some local codes that have a 4" minimum. 7" is pretty comfortable for most folks.
That said, for me 5.25 which would be about the necessary rise for 47" total rise, would be pretty shallow, and would require rather long tread run's to be comfortable.
In the State of California , like most states I am familiar with , the Stair code is mandated by the State and designed with Blind people in mind , not your personal taste.
In Forty years of working as a Union Carpenter and licensed General Contractor , that was the code I worked with on hundreds of stairs I either built or were built in subdivisions I was the Superintendent on.
7" is the Min. and 8" is the max. and the only place I saw where that was not observed was in Old Lady Winchesters House of Mystery where she had stairs reworked with a 4" riser system called "Easy Risers" and that was long before any code was in force.
For people who may not know, outside the trade like you , this is part of the formula for ensuring that the stair rises at a angle between 30 and 35 degrees.
For in the field calculation purposes this is attained by having the tread depth and two times the riser height added together, come as close to 25 as possible.
For example , a tread depth of 10 inches ,which does not include a Bull nose overhang in the ten inches, plus twice the riser height of 7 1/2" gives you the magic 25 number and a angle of rise between 30 and 35 which is ideal , though not exactly that in all cases where the run is constrained, so you get as close as you can.
In Carols case what she does even though she feels comfortable with what she wants, happens to not conform to stair code in Arizona, can come back to haunt her in two ways, somebody may fall and hurt themselves and head to the nearest personal injury lawyer or be noted by a Home Inspector like Barry as substandard steps when she elects to sell and be required to make it right.
So you are saying that residential code is a minimum of 7" riser height because of blind people's expectations. I have no argument with that. If my arthritic knees can't deal with 7" then I am forced to a handicap ramp at, what, no more than 5�. Is that right? There is no in-between?
I would be interested to hear Barry's comments.
Incidentally, for grins, the three existing steps at the end of the porch are at three different riser heights. And the stairs off the back deck are super steep angle-wise and have differing rises at the top and the bottom. Just another thing that I have to change. But one set of stairs at a time!
Its not unusual to find stair risers shorter than 7" on public use buildings, usually the locations are front steps where the architect has decided that low deep stairs look good, or in auditoriums where they're keeping to the slope of the floor without making it a simple ramp. I notice shorter risers because I find them awkward.
Local jurisdictions often make exceptions to what ever code they're following (called amendments), though they usually seem to make their code more restrictive than less. For all the back and forth insisting that "code says" one thing or another, evidence would lead me to believe that many jurisdictions do not follow the 7" rule, or it is recent (say the last 10 years). California is well known as a very regulatory state, just because it is the rule there it is not necessarily the same throughout the country.
If you want to follow your local code on the stairs, you have but to ask at your county or city permit office, or look on the web for the code they follow and a list of amendments to it, or best yet, ask the inspector (the inspector is often much more sensible than the people in the office). Its important to know the amendments, NM for example has several to do with local climate and improving grounding of electrical systems - what works in Georgia does not work here .... yet they still follow the attic and crawlspace venting guidelines written for much more moist areas... Building codes will no doubt soon be as bad as the tax code
You don't want to put all that mass on a wood frame stair
You could have poured concrete or cinder block stairs going up to the porch if you wanted the stone look. All that masonry is a bit of a pain though if you're doing the work yourself, and added complexity and expense if you're hiring it out.
I think painted and sanded treads are the way to go, as you don't want the maintenance of Ipe or similar, and are presumably not going to get a welder to make them out of steel
Our front steps are Ipe with tiled risers, you can screw 1/4" hardibacker to plywood or OSB on the risers, then tile the hardibacker. Only things to watch out for are weight and to add some depth to the stair for all that material. An extra stringer might be a good idea, that's what I did.
I just looked this up in the IRC. Not the most current version and i don't know what version is in force where you live, but it should be very similar.
It calls for a maximum rise of 7 3/4" and a minimum tread width of 10". No mention of a maximum tread width or a minimum rise. They do say that the maximum variation of any tread to any other tread is 3/8" and the same for the risers. The nose should be between 1/2 and 1 1/4". the nosing does not count as part of the run, its the cut on the horse or stringer that dictates.
Read over what Fred wrote. He got it right.
For years 7 in 10 was considered "perfect" and is still something to shoot for. Fred's description of how to stay close will help. If you get too far away from that, the stairs will become awkward. For example, something like 4 in 12 does not suit your gait and you will have to sort of shuffle up them.
The 3/8" variation thing is important. If the stairs are variable, they become a tripping hazard, quickly.
Locally, they usually permit somewhat more variation on exterior stairs as far as maximum rise and run, but they are still sticking tight on the 3/8" thing. Also, they used to allow the bottom step to be "whatever", so it might have a four inch rise, not anymore, it counts too.
Stairs are a huge topic. Books have been written on them. Now days, if you can build steps and cut rafters, you d' man in the carpenter world.
Depends on your experience and what your source is Howard.
On checking stair code for California , which was in effect since 1927 John, in 2008 made what looks like to me to be a huge departure from 1927 all through my work life.
They have adopted what Barry refers to in the IRC as max and min run and rise and allowed wood butchers to enter into the construction of stairs by allowing 3/8ths difference in rise from step to step.
This is a blow to people who can't see or are otherwise handicapped because of the change in rythm in the stair run.
"7" is the Min. and 8" is the max. and the only place I saw where that was not observed was in Old Lady Winchesters House of Mystery where she had stairs reworked with a 4" riser system called "Easy Risers" and that was long before any code was in force."
I pointed out that is not correct. The CA code says that 4" is the minimum. You regularly state things from CA building codes that are incorrect. The fact is that normally no one call you on it. You need to admit that you are occasionally wrong. Nothing wrong about that except it may hurt your ego some.
Ipe is an ideal tread material and only adds work if you don't mind that it changes to an attractive grey color. It will last for decades with only an occasional cleaning.
Just finished front steps out of Azek decking. Easy to cut or rout. used it for treads and risers. underneath was pressure treated with thin strips of WR Grace roof underlayment laid on top of the PT to protect it in the gaps. Built a deck from the same stuff two years ago with excellent results no discoloration or mold and this is on the Maine coast so weather extremes are common here too. http://www.azek.com/azek-deck/ is the website
In essence there is no minimum height of the riser for a porch or deck in Gila County. There is a requirement that there be no more than 3/8" variation in the risers on porch stair system.
IRC is short for International Residential Code. It is my understanding that the three major code groups BOCA and whatever the other two were have melded into a single group and combined their various codes into the IRC and that it was adopted Nation wide. No more local, state or regional Codes, one Code for the entire country. I don't know what other countries have adopted it, so it may not be truly international. I could be wrong about the adoption. I am not very political and don't really care if California or any other state even has a building code, let alone what it looks like. The Idea that California, North Dakota, Louisiana, Puerto Rico and Virginia all should have identical Codes strikes my as ridiculous. I can't even spell Puerto Rico, but you get the idea.
The 3/8" restriction is some committees idea of "good enough". Just because they permit 3/8" variation does not mean you should have it or that it represents good workmanship.
A common mistake I see is the set of steps that has three risers. Say from the dining room down into a sunken living room. They cut the stringers or supports so that they are all exactly 7". Then they install the treads. Now the bottom step is 8", the middle one is 7" and then top one is 6". Its a neck breaker even for sighted people. If you start from the top, you adjust to that short rise, then longer and then even longer. You end up running, if you are agile and lucky.
