Cutting long sliding dovetails?
I just used my Leigh dovetail jig to cut 18" long sliding dovetails. Basically you insert a filler strip into the front edge of the fingers, turning them into a straight edge. You route the slots across the work piece with the panel in the horizontal position. Then you rout the dovetail on the ends of the other piece with it in the vertical position. The problem is you have to sneak up on the width of the the tail by creeping the fingers/straightedge into the workpiece. I found this to be very tedious. A case were one or two hundredths of an inch made a huge difference. And, it is related to the thickness of the panels. So if one panel is a few thousandths different, the fit changes.
Seems to me the process is fundamentally flawed. By indexing the cuts off both faces of the panel all kinds of possibility for error creeps in. It would be better to have a jig that has two straight edges that set the distance between them so that the tail is correct no matter what the thickness of the panel is.
Am I missing something? Is there a better way?
Re: Cutting long sliding dovetails?
AZ in Colorado Springs
Barry, what you say makes sense. They are just offering another use for their jig, as a marketing ploy. Doesn't mean it's a good way to use the jig. I've used the Leigh jig to make "regular" through and HB dovetails, and it worked very well. I have not used it for sliding dovetails. I think that's just a marketing technique.
Cheers
Jesse Cloud
Don't know anything about the Leigh jig, but when I do long sliding dovetails, I give them a very slight taper, say 1/32 over your 18 inches, so the fit gets tight only at the end. Makes assembly a lot easier.
That's exactly what I do when I have made them in the past. When I used them to attach table legs I cut them on my router table. I applied a couple of thicknesses of tape to one end to make the taper. Makes them drive home really nicely.
I'm just thinking there shoudl be a really slick way to do these.
I think you are exactly right. This is an after thought option that works, but not really well. If there were micrometer adjustments It would really help.
Bruce, a MN Galoot
I agree there should be a slicker way, but when I've made sliding dovetails, I've used the process exactly as you describe - router table, with a couple thickness of tape on one end.
An easier way, better by half
bill tindall
If one looks at old stuff it will be discovered that a half dovetail is often used for drawer dividers and case bottoms. Such an arrangement leaves one side of the tail a flat surface which can then be adjusted with a hand plane.
We did a sliding dovetail when I did the class with Headley and they did not advocate tapering. It is unnecessary. The joint was fit until it could be easily assembled with hand tapping, then glue applied and the joint slid together.
They have assembled hundreds of case pieces this way so it has stood the test of time and practicality.
