We value your privacy.
I usually cut stair stringers out of 2 x 12 lumber. It was the way I was taught. i have cut stair stringers out of laminated OSB before - that also works for me. For a 3' wide (or 4' wide) staircase, I usually have 3 stringers.
Now - for a stage set - which is not permanent construction, but does have to bear weight for several weeks worth of rehearsals and performances - I should still do the same - right? IMO, using a 1 x 12 is just asking for trouble. I've had them split on me far too often.
Also - anyone know any good "formulas" for making a "spreading" staircase?? I want this one to spread out on the bottom by maybe a foot or so.
I have cut them out of 2 x 10's. They were OK. Pick clean ones with no knots in the lower edge. I would think you can buy 2 x 10's or 12's as cheap as or cheaper than 1x12's. And if the 1x's are knotty, you know one of the knots will get you.
how long the steps were or whether they were supported or open or what. If the stair stringers are nailed to a wall on both sides and have risers, you could build them out of most anything. The risers would carry the loads to the stringers and to the walls. If this is a long open flight with no risers, its a different story.
JL, you could make the stringers out of 3/4" materieal and then glue a strip up both sides of the parts under the steps. Teh triangles supportingthe steps woudl be 3/4" and the continuous part could be reinforced with one or two 3/4 pieces or a 2 x 4.
I'm thinking make the whole thing out of one inch thick decking plywood. One sheet might be enough. You probably have budget restraints? If so, might be too costly. Just a thought.....
I don't know, 1" ply is pretty strong stuff. Plywood is often used to reinforce headers, like a garage door for example. Decking plywood is glued better than ply that is meant for indoors. Use decking screws to hold the whole thing together and pre-drill when you are screwing into an edge.
The beauty of using Deck Plywood besides it's superior strength thickness wise , is the ease you can make the stair horses any width you want , not being confined to structural lumber sizes.
each about 12' long. I've got to go from stage level to a platform that is about 8' up. If I can find the decking plywood - I would need to piece it to get the 12' length. I don't have a problem with plywood (especially for stair treads) - I have used laminated OSB for stair stringers - I suppose I could make some laminated plywood lengths for stringers. The unit cost would have to be pretty reasonable though. It costs about $12 for a 2 x 12 x 12' around here.
My main thing is weight - a 12' length of 2 x 12 is pretty hefty. If you are the person who is carrying most of the weight... The other problem is warping - I've had quite a few 2 x 12s assume some "interesting" shapes.
Sorry Jl, for some reason I was thinking something shorter. Plywood wouldn't be practical for a 12' height. Looks like you'll need to go with the 2 x 12,s. If you have to start with green wood, I would use a good primer on them right away right after you cut in the step angles and allow as much as possible to soak into the end grain. This will slow down the shrinkage and less warpage. Or better yet, get some of that stuff that the turner,s use for their green wet freshly cut wood chunks. Run over to the turner,s forum here in WC and ask what it is and where to get it. What the stuff does is, it soaks in and replaces the moisture that's in the wood and prevents cracking and other horrible things that happens to wood when it dries. Perhaps using plywood on the treads will reduce the weight to some degree. If you can find some kiln dried 2 x 12,s, they would be less weight but more pricey of course but then you wouldn't have the cost of the sealer or primer.
When I built my house, I used several 12' green 4 x 12,s that had to be in the sun for more than a week. I gave them a good coat of primer after I cut them to length and before I put them in place and got very little cracking and warpage. The primer was white and reflected the heat to some extent.
I know you are building a stage set and you want to roll these around (?) and they are indoors and they only have to last a few weeks and not kill anybody, in the mean time and they will be lightly loaded (?) with only and actor or two on them, not the entire cast and a piano (?)
So if light weight is important, here are some suggestion. Make two horses or stringer out of 3/4" x 12" material. Pick pieces that have the equivalent of a 1 x 4 along one edge that is nearly clear and free of knots. Cut the triangles out of the knotty side, leaving the clear side intact. Save the triangles.
Make the treads out of 3/4 stock and the risers out of 3/8" plywood. Cut a rabbit into the bottom of the tread to accept the top of the riser and glue the riser into the slot. 1/4" deep slot will be fine. When you assemble the stairs, glue the front of the riser to back of the preceding tread and staple or nail it.
If you want to, glue the triangles you saved in place one one or two rows under the stairs. Cut might be a little sloppy, so this might be a good application for construction adhesive. A couple of Kreg screws up into the treads might be good. You can nail them from the out side, but finding them with the nailer might be tedious.
If you want the tread to look more massive, glue a filler strip to the bottom of the front edge and then cut a nosing. If you do this, you don't need the slot mentioned above, the face of the riser could be glued tot he back of the filler strip. Or, you could just round over the top edge and apply a scotia molding.
Build them and check them out. If they need to be stronger, beef up the part of the stringers below the treads and if necessary, add strips up the bottom of the triangles. Add a 1 x or 2 x to them.
