Cutting long 45's on TS Question
I am trying to make some night stands for my son and DAD's bed. they are made of walnut panels that are 18" wide. I want to miter the corners, as if I took a board and folded it in two places. These are cross cuts. Ends up very "cubic". So, how to do it? I have a right tilt table saw. yesterday, I did a practice run on some scraps. cranked the saw over to 45, and moved the fence to the left of the blade and ran both pieces. I may be wrong, but I like having the piece on top of the blade. Then I slapped a few biscuit into the joint and clamped it up. It came out at about an 89 degree angle, just under 90.
My practice pieces were short but wide, so I was able to use the fence even though they were cross cuts. My fence won't go far enough to the left to allow for this procedure on the actual cuts, but it will move far enough to the right. Should I use the fence or a crosscut sled?
It seems to me that there should be a way to do this that assures a perfect 90. Do you run one piece on top the blade and one under the blade? One flat on the table and one standing vertical? Or do you just tune the saw and have at it?
Kind of like a shooting board
