We value your privacy.
I have some of the buffing pads that are plastic (?) "steel wool" sheets. Not sure, but there are green, maroon, Gray and maybe some white ones. I've lost the packaging. Can somebody tell me what their coarseness is and how they relate to steel wool. Which is the most coarse? Don't the white ones lack abrasive at all? and the others have some grit in them?
And, Do you like them for finishing? My son is stumbling through finishing his bed and has managed to get steel wool fibers in the finish. Any suggestions? Anyone tried putting one of the pads on a ROS?
Barry, I'm not sure on several of them but I do know the white is supposed to be nonabrasive. I think the gray are about 150 grit. I also think the maroon is the most course.
As far as using them during finishing, I do not. All I ever need is some 320 and/or 600-grit wet/dry paper. In preparation of the wood before finishing begins, I always use sand paper in one form or another. I do find those pads more useful on refinishing work, however.
I use the maroons for de-nubbing and clear coat prep, especially after staining, as they are less likely to cut through. Also after the base coat of clear lacquer. The others aren't of much use.
