Regarding Squares . . .
Robert R. Clough - Thorncraft
I must "square up" one which belonged to my Grandfather a bit over 110 yrs ago. The problem is that it is a small square and made of armor plate, I think!. It is roughly out of square, too open. The square is about 1164th thick an I cannot use the punch method but the ball peen, large, might work.
Suggestions anyone?
Re: Regarding Squares . . .
FredD
I have two 8x12 Stanley squares and your right, they are hard and thick and neither has a peen mark on it , so I think they may have gone trough a slightly different manufacture, they are both dead on .
The two newest Framing squares I own are Mayes brand and both have a small 3/4 circle out of the inside corner , so there is something different from Peening.
I wouldn't use a large Ball peen , like a Machinist hammer Robert, I think without actually trying it , that a smaller Ball will move the metal easier.
Heating the area with a Gas torch first should help the metal to expand if that is the direction you need to go.
FredD
I wonder????
If you heat the square in the corner, it may move out of square because of uneven thermal expansion. I actually don't know, but I would assume you would have to heat it, peen it and wait for it to completely cool so that all the metal was at the same temp. before you could check it to see if it was still square. I've never tried heating a square, but it just seems to me it might not work well.
Re: I wonder????
FredD
Barry his square is already out of ninety.
I suggested heating the metal because it will expand , exactly what you want if the ends of the square need to move away rather then toward each other.
The other reason for preheating the inside corner is to increase the likely hood of his Peening being successful given the thickness of that particular square.
If you have a method that is promising , I am sure Robert would want to hear it, I know I would.
FredD
Re: I wonder????
Fred, I don't have a method, I am a nattering nabob of negativism. I was just pointing out that heating it might warp it and you wouldn't be able to tell what you were doing or if you had been successful until it cooled down. and besides, if I heated my square, I would burn myself.
