How to make a square, square......again
bill tindall
Background: I was cutting the sides of the chest I am making to length and checking squarness. Measure one way and the end cut was dead on, the other way it was off 1/32" in 22". The only way to achieve this result is for both the square and the cut to be off a 1/64" in 22" so that in one orientation the errors canceled and the other way they added. A check of the square revealed it had gotten off since its last adjustment, or I never got it perfect the last time.
To close the inside angle of the square one punches (and/or pounds with the hammer) on the outside corner of the square. The expanding metal closes the internal angle.
Now, one may wonder why I have punch marks on the inside of the square's corner. Would prefer that question not be asked because the answer will get into a prior screw-up I would rather forget.
