Glue-Up Questions
Glue-Up Questions
Glue-Up Questions
I'm about to glue up a "bowling-ally" style maple table top. The finished top will be 34"x54" by 6/4.
The top will be supported across its width at three points.
Question: Would it be advisable to drill and dowel the lamination together at say 2 or 3 points for registration/stability? Glue will be TB III unless someone has a better suggestion. Table will be for internal use as kitchen island with oil finish.
TIA
Re: Glue-Up Questions
Steve Schoene
Doweling for alignment is very hard to actually accomplish, what most often happens is that you assure a degree of misalignment. I prefer using cauls to help keep things aligned. And doing that many edges at once is a challenge. I would glue it up in manageable sections so I can have time\ to work on getting the alignment really right.
I wouldn't dowel them
Mark, I suggest using three pairs of waxed beams or cauls to clamp the assembly flat while you cinch up your bar clamps. If your cauls are stiff enough or crowned appropriately, you will be able to keep those parts in very close alignment -- close enough for your Performax.
Re: No Dowels, check
Yup, the Performax is definitely in the future here. Stock was ripped to 7/4 so I've got a quarter to play with on the sander.
I figured to do up 4 sections. Then the center joint, followed by the outside edges.
Thanks
Ripped to 7/4 for some wiggle room, but done on the band saw so I'll concentrate on getting one face flush, then take it all done flush and straight on the Performax (22-44 Pro).
Thanks
Glue choice
Dave Bair, Eaton Rapids, MI
I used TB-3 on my 6-board dining table. It has developed a glue line at 2 of the joints. Wished I had used plastic resin glue but it was a winter project and I wasn't sure I could maintain the 70� temps required. Wouldn't be a problem this summer.
Re: Glue choice
Stuart Johnson
I don't like TB3 for just that reason. If it is for indoor use I would use original Tightbond.
Mark, When I do glue ups like this I slap a few biscuits in the joints for alignment. I lay the strips up, draw lines across the stack and Cut all the slots.
When I do the glue up, I don't bother with glue in the biscuit slots, I just let them keep the face lined up. I would do this in two or three pieces, leaving one or two joints dry, but I would glue all the others at one time and clamp the whole thing. After sanding the faces into submission I would reassemble it into a whole. By clamping the whole thing at one time, you are assured the dry joints will mate properly when you glue them. I have a 6" long bed jointer, but would not want to try to joint that long joint in that massive a piece by myself. You might leave the slots and biscuits out of the dry joints so that after it is sanded, you can add biscuits and they will register off the newly sanded faces.
I think it was you who mentioned using in feed and out feed rollers on the Performax. I added them to mine and I highly recommend them. For panels this size, they will be a god send.
glue likely was not your problem
bill tindall
The most common cause of a joint showing is gluing together lumber of different moisture content. I have dozens if not hundreds of joints in furniture in my and daughters houses made with yellow glue and none are raised or otherwise noticeable.
It is a fact the most furniture factories use yellow glue with out experiencing the problem you describe so the odds are not with the glue.
my experience in this kind of glue up
bill tindall
I presume by "bowling alley" you mean gluing up strips.
The problem with this kind of assembly is that it is hard to keep the pieces from squirting out of alignment while tightening the clamps. You can mitigate the problem by slowly tightening clamps while bashing the recalcitrant into submission, using glue sparingly to get fast tack, and some sort of arrangement to hold the pieces tight against the clamps while tightening. I rarely resort to the last suggestion. Don't underestimate the value of using glue sparingly to minimize "squirt-out.
With the equipment I have at hand I would glue up 2- 18" wide pieces, send them through the 18" thickness planer and then glue these two panels together. I can always make one near perfect joint, if done one at a time.
I would prefer a fast tack glue for this task, again to minimize squirt-out. I find I can do everything I ever need to do with plain Tightbond.
Cross Grain with Dowels
Howard Acheson
Using dowels as you suggest would create a cross grain situation. It would tend to prevent the natural seasonal expansion/contraction of the lamination. Something would have to "give"--it would be either splitting or glue joint failure.
