Windsor chair find
Windsor chair find
Windsor chair find
Gary Smyth
Found this chair yesterday. From where I found it perhaps 1950's or 60's. Childs size Windsor and built decently. No date and the label is about 85% torn away so I can't report a label shape. I tried several pics for the label but no luck. From what I can see the label was red letters on black background and it appears to say Hi Noon, Chair Company, either MI or MA. Another version might be "Union" but the letter spacing is ghostly and cannot tell. The label reads "(torn)----ON CH----, ----ANY, ----ON, MA or maybe MI. The label is missing here so it could also be Minnesota, Maine, Maryland, Missouri, Mississippi. (The spaces are spaces and do not indicate the number of missing letters.) I checked around the web and several Windsor and manufactured furniture books and can't find any reference to anything like either of those as stated above. Anyone ever seen one of these or know of a company that might fit?
Re: Windsor chair find
Add on note:
Gary Smyth
Additional portions of the label on the chair with oblique light may be readable. Does anyone know how to dust for letters? If I do a rubbing with graphite or dark stuff I will make what appears to be label letters go away. Suggestions?
Re: Add on note:
Stuart Johnson
You might try taking some high resolution photos at an angle without flash and see if anything shows.
I tried using straight non-digital photography
Gary Smyth
and the slides should be back Tuesday or Wednesday. Three versions, Nikon 35mm w 105 MicroNikkor focusing to about 8", a 55mm Nikkor that focuses to a little over an inch, and a Minolta with bellows, formerly used for photos of duplicate slides. I'll see. Problem is that my artificial light source has more intense and less intense sections of the beam at an angle and it cancels out the letters. I have a ring light but it was too dispursed and flat. At the best look I can get a "shadow" which shows promise of greater joy but I think additional contrast would help. So far, my eye with a good magnifying lens is much better than anything working off of my digital. As for film, ???. This is where an 8 x 10 view camera, high contrast film and a budget would help.
paul in AZ
Doing some poking around using 'Union' as the first search item and found a Union City Michigan. Grand rapids area. More quick searching: Appears there used to be numerous furniture factories in the Grand Rapids area. Not unusual to see furniture manufacturers considering the hardwood forests there.
Prior to long distance shipping stuff was built locally and stayed there. I see no indication of where you are or where you found the chair.
Could this be it's town of origin???
addendum
paul in AZ
could the label be Union Chair Company, Union Mi.??
Paul, Could be, I'll keep it in mind. I
Gary Smyth
did locate a Union Furniture (not chair) Company with offices in Grand Rapids, but as far as I can find they made classic mahogany desk/bookcase secretaries mostly. Thanks for checking, maybe it will work out. I'm in Western PA, nearest big city is Pittsburgh. The chair came from a reasonably well to do home. The owners were capable of moving and probably did when the male worked for U.S. Steel.
