REAL MILK PAINT
How to cut large finger joints Question
My son wants box joints or finger joints on the top corners of his night stands. Something like the large dovetails often used on blanket chests, but without the angles of the tails. The wood will be 1 1/2" thick, so he wants the pieces to be roughly cubes. Alternating nominal 2" fingers.
My question is how to cut this joint. I know how to do a box joint with ajouter table or a table saw, but I have always done them based on the cutting width of the bit and I don't have a 1 1/2" bit. What about using a Leigh dovetail jig and use the straight side only?
Any thoughts?
Re: How to cut large finger joints Question
Pat Evans
While box joint jigs normally are set up to cut the fingers the width of your dado set or router bit, it doesn't have to be. With a little fiddling, you can make your jig for any width finger and just make multiple passes to complete the cuts.
Brent Smith in Montreal
Leigh has the M2 template for M&T and larger finger joints. It handles stock up to 1 1/2" thick and can be variably spaced just like their dovetail templates.
Joseph Mulherin, Sr
Why buy another tool for just one project when you can do the entire work on your table saw? Use your carpenters square and mark the board with the 1/2" marks spaced as you like them and maybe alternate with the 2" side also.
Then make the outside cuts of the fingers entirely on the board first, the go back and forth and remove the interior parts of the fingers. Use the already cut fingers to mark out where the matching fingers will be with the opposing side, then cut the same way. They will meet and match perfectly. Then glue up and sand as needed for finishing.
FredD
Since your familiar with cutting box joints you can continue the process with a couple of changes.
Using a sacrificial cross cut fence with the blade height set the way you want it ,
hold the fence against crosscut fence with a few inches sticking out to right and cut a slot the same size as your blade. Move the fence to the right of the fence the size you want the finger and cut another slot.
Glue a finger in the first slot about a half inch high , screw the wood fence to the cross cut fence ,with the second slot mounted over the blade for the distance setup.
Repetitious cuts after that.
Remember you will only be making two cuts for each finger initially, when all of the outside cuts are done , then you cut out the center with just using the crosscut fence without the temporary one installed.
Because the ATB blade your probably using will leave a tiny Vee shaped gutter , I would install a Rip blade with it's flat ground teeth, you will have a perfectly flat bottom in each cut.
Or buy a Leigh jig for much more ;-))
FredD
Do you think this would require a blade that cuts a flat bottom in the groove? I use a Forrest WW11 most of the time and am not sure I have a flat top blade? What do you think?
Fred, I cut box joints just often enough to forget how I did it. I can't remember how to index the cuts. I remember about the piece you glue int he slot, but I can't remember what causes the male and female to line up. Can you explain?
FredD
Just in case this isn't a test Barry, the typical box joint male and female sides and ends are held together two at a time with with one offset a full finger size and cut at one pass with a dado set for the required width or just using the saw blade .
This will not work , because for the size of the fingers your Son wants to cut.
If you set up a Dado head for the cut , the height of the required cut would make it a extremely dangerous thing to try.
So , cutting the fingers like I said and then using one cut side or end for a template , mark out the slots, like a previous poster said and cut out the slots.
This will be fairly tedious , but nor more so then hand cutting Dovetails .
FredD
Alan in Little Washington (NC)
Barry,
It is easier to make the jig and cut the joints than explain it, and easier to illustrate with 4 -5 simple diagrams so let me know if you want me to work up a set. But, large box joints can made accurately using a simple, temporary box joint jig that indexes the stock, a dado blade, and multiple passes on the tablesaw.
Make the jig:
1. Install a dado blade in your TS. Set the dado to the widest cut it can make to reduce the number of cutting passes required.
2. Cut a notch in 1 X or 2 X 4 temporary miter gauge fence with the dado.
3. Fashion an alignment peg that will fit the notch precisely and snuggly. (if you must trim the peg to fit, ensure you trim the whole peg, not just the portion that fits the fence notch)
4. Position the fence so the distance between the inside of the alignment peg and the outside of the dado blade is equal to two times the desired finger width.
5. Make a spacer the width of the fingers to align the stock for the first cut.
Double check all measurements.
Start by making a notch in the end of the stock:
1. Place the spacer next to the peg, between the peg and the blade.
2. Butt the stock against the spacer and make the first pass.
3. Back the stock away from the blade after each pass to remove the remaining notch material to the end of the board.
To make the second notch:
1. Hold the spacer against the outside of the peg.
3. Make additional passes, but, this time advance the stock towards the blade after each pass until the finger meets and is stopped by the peg.
To cut the remaining notches:
1. Set each notch over the peg and make repeated passes while sliding the previously cut notch, side to side, against the peg.
To cut the matching (finger end) stock:
1. Flip (end-for-end) a piece of stock with a notch end and place the notch firmly against the outside of the peg. This is a temporary stop.
2. Place the stock to receive the finger end against the stop.
3. Make a cutting pass.
4. Remove the stop, then slide the stock towards the blade while making additional passes to finish the notch.
5. Continue making additional notches as described above.
Jig for making 3" wide finger joints:
Re: How to cut large finger joints Question *LINK*
Dick Coers
I suggest the Kehoe Jig. I've had trouble making 3/4" box joints in a blanket chest with a dado head. There is so much friction on sliding that big stock vertically on the saw. Then trying to index really accurately would almost be impossible. If you try it, read up on adding veneer or slices to disguise gaps in joinery. Then how about running a dado head through the thickness 1 1/2" hardwood. Take the batteries out of the smoke detector. Also be aware that as the width of the stock adds up, so does the friction. If your test cuts slide together just right on a 6" wide piece of stock, you will have to drive it together with a hammer at 16" wide. Good luck!
Kehoe jig
dick, This is amazing. I have one of those I bought about 12 years ago at a show and have never taken it out of the bag. I thought I was the only sucker that owned one. Thanks for posting that link. Now I get to bring it out and use it. Even if I don't use it on this project it will get to see the light of day, or at least the fluorescent lights in the shop. Do you have one and do you use it? Does it work as well as advertised? I have to go look, but I don't think I got as much of a kit as he showed.
John McGaw
I'm having a hard time visualizing these roughly-cube fingers. Normally the fingers are narrower than that -- the idea being to maximize the glue area. I would probably consider 1/2" to 3/4"-wide fingers to be more appropriate for 1-1/2" stock. In any case, the method of cutting remains the same and you can set up a jig for either the tablesaw or router table to do the job in roughly the same was as you would for tiny joints.
Dick Coers
Sorry, Barry, I don't own one. I've not even seen how they work in person. I just like the idea of taking the fixture to the work when the work is big. Maybe my age showing again. I've never read about anyone not liking it, so I did a quick Google and came up with an independent review for you to read. Good luck.
Tom's workbench
FredD
Barry, I can't speak to the Kehoe jig , never had using one , but I agree on his advice about Dado blades in 8/4 stock 100 %.
If you install a Dado head as wide as it can cut (13/16ths) and 1 1/2 " high blade elevation and run Black Walnut into it repeatedly , you will have entered the Twilight Zone of saw safety.
Don't do it. or even worse letting Son do it.
FredD
I got mine out and literally blew the dust off it and put it to use. It worked better than I expected. Made a mock up joint out of scraps. Actually pretty well thought out. Thanks for the reminder.
