Re: Router table lifts
George Colonel's Workshop-Havertown PA
Good Afternoon Hamish,
One upgrade which I will make to my latest router table is a "T"-track running across the width of the top, primarily to mount feather boards. Otherwise, I have been satisfied with the operational portion of the table design. I suggest you pay particular attention to the evacuation of dust.
I presently use a 2 1/2 inch aperature ported commercial aluminun split fence (Penn State Industries), and connect my shop vac hose to that. DC from the fence is most effective. I have a large hooded vent mounted to the inside of the cabinet back, and it has a 4 inch opening connected to my DC plumming. It isn't as effective as my previous table which incorporated a plenum at the rear of the cabinet, around which dust was drawn to the back exhaust port.
As to the lift mechanism, the Axeminster chain drive may be affected by dust accumulation, and represents another reason for good cabinet design. In fairness, my JessEm Mast R Lift has remained easy to raise and lower, given frequent sweeps with a vacuum nozzle. It is prudent to vacuum any lift mechanism anyway.
I certainly agree that a mechanism premitting above table bit height adjustment is a beneficial improvement for all light/medium weight routers, and a necessity for the heavy weights. They decrease the work and set-up time, and increase the fun and quality of cut.
Please post a pix once your set up is made. Good Luch,
George
