Computer Virus Question? OT
My son has a laptop he bought from Best Buy and is using Web Root Spy Sweeper as recommended by them. Now when he turns it on something comes up and tells him he has a "Dangerous Internet Virus" and sends him to a website that tries to sell him virus protection. I have not seen it, but he says the site has no ID or Name Brand type info. He thinks its a scam, trying to sell him virus protection.
Can someone tell us how to get rid of this so he can use his computer?
(He's running Windows 7 and the computer is less than a year old.)
Re: Computer Virus Question? OT
del schisler
go to control panel and scroll down and remove Web Root Spy Sweeper. Shut down comp and than reboot comp. If their is still something left or something come's back up. Which i doubt. You should be good to go. now if something is still their. Go into regester and find all the item's that have any root spy sweeper in their. Delete all. This will get it off the comp. The only virus program .I don't use any . I have a router and Zone alarm I haven't had any virus. I use malwarebites This will remove lot's of junk. It is free. Most other program's slow comp. down like avast. avg. Norton which i wouldn't use . Also mcafee is another one . If you watch where you go and your email You should not get a virus.? my 2cents
Jesper, Denmark
Jesper, Denmark
Let indows remove the program first.
I use Windows security essentials and Malware bytes on all three of my computers. No slow-down and no costs.
I had Norton in the past - very invasive and hard to get rid of again. AVG and Avast both worked OK, but had some disagreements with Windows vista.
Bill Howatt
The problem may not have anything to do with Web Root Spy Sweeper since I think it is a legitimate well-regarded program (I have never used it thought).
The symptom sounds like he possible clicked on one of those dreadful links that ask to scan your computer or tell you are infected. When you do it then infects you with the annoying message that you can get rid of by buying their product which does nothing but get rid of the message they put on the machine. They can be difficult to remove manually.
Routers and firewalls will do virtually nothing to stop this kind of infection because by clicking on the ad/link you are instructing the computer to bring in the data and the firewall will let it through since you requested it.
Bill
John McGaw
The site he is being directed to is a scam but they are not trying to sell him virus protection -- they simply want the money and if he downloads and installs anything from them he will be installing something even worse. The hard truth is that, if the computer is relatively new and has not had much content added, he would likely to be better off screbbing the entire contents and re-loading the system from the maker's restore disk or partition and considering it a life lesson.
Cleaning a computer (I've done more than I care to think about) is possible but the technically-non-savvy are not often successful and sometimes make things worse before giving up entirely. Sadly, many never learn from the experience and do it again and again. Just my $0.02 of course.
DANGER WILL ROBINSON!
Jerry Nicholson
WARNING WARNING WARNING
DON'T mess with the registry unless you know what you are doing. If you are going to edit the registry, be sure you create a restore point FIRST. If you don't know how to create a restore point, you probably don't know how to edit the registry. Any changes made to the registry take effect immediately. There is no undo or undelete command in the registry editor. A mistake can render your system unstable or completely unuseable.
As a side issue, completely removing Norton Antivirus from your computer involves extensive registry editing. I have found the latest version of Avast to work OK with Windows 7 but I prefer Zonealarm Antivirus/Firewall.
Jerry
Bart Goldberg
Re: DANGER WILL ROBINSON!
Bart Goldberg
I edit the registry all time time when I find programs that don't clean themselves up completely. I've never had a problem as you describe.
Jerry Nicholson
I have done a lot of registry editing too, and I haven't created a real problem yet BUT the potential is certainly there. The registry editor is completely unforgiving and provides very little help, hence my warning.
Jerry
Dave Paine
Web Root Spy Sweeper is a malware program. It is very good. I happen to use on 4 computers.
Malware protection is to prevent the background programs which can slow down a PC, and send data you are not aware is being sent to some sites.
Web Root also sells an anti-virus add on, which I am also using.
The message it likely spam at best, or at worse going to direct you to a site which may try and sell you something.
Try and force a system re-scan. Have to open Web Root. It normally does a systen scan once a month.
Web Root has protected my PC's from malware and virus's. I have even used it to clean up other people's hard drives which have had virus's.
David Yoho
I've been using Spy Sweeper for years and it does a great job. Still, something has loaded onto your computer that got by Spy Sweeper. I'd recommend downloading and running Malwarebytes anti-malware program that is free. It will easily find the culprit and remove it.
As long as you don't click on anything from that link or site nothing should happen until you can remove it. This is a common malware problem that seems to effect a lot of computers I've worked on but is easily fixed.
BrianA from Monument
You can take it back to best buy.
The geeks can fix it.
Once that is done......
You have two choices;
1. continue life with microsoft windows virus plagued junk.
With file scanning eatting most of your systems bandwidth.
2. install Linux on your PC and move on to a more virus free system.
Prior to a thunder and lightening storm this very PC I type from had
been running for more than 45 days.
For a laptop that is a pretty good result.
I don't have to wait for virus or malware scans.
It is not vulnerable (relative to microsoft junk) to viruss.
Brian.
