steam
bill tindall
It is often thought among hide glue enthusiasts that only hide glue can be loosened by steam, but in fact the technique for disassembly of a PVA joint is the same as for hide glue and it works equally well.
You will need to make a steam generator. A local furniture restorer made his from some coffee making device that requires steam. I use a pressure cooker, placing a plastic hose over the top vent in the cover and a basket ball inflation needle on the other end.
You will need to drill a small hole, to accommodate the needle, into the joint. I like to drill the hole trough the tenon stopping before exiting the other side of the mortise. This way the steam easily gets to both sides of the tenon. Insert the needle, make steam and wiggle the joint now and then to determine when it gets loose. It will take a few minutes. The joint will suddenly loosen and come apart like it hadn't been glued.
New PVA glue won't stick to cured PVA glue, so next you will need to remove the PVA glue and in this regard hide glue is advantageous as you don't need to remove it before regluing. (If the proper solvent is added to the old PVA joint the old glue doesn't have to be removed but this operation is beyond the scope of most repairers.)
