Baseball Stand
Doug Reynolds in Seattle
A friend asked me to make a stand for a crystal baseball. She was wanting something like a dished block of wood. I could use a forstner bit or, scoop it out on the lathe. Any suggestions? TIA, Doug
Baseball Stand
Re: Baseball Stand
steve mackay
I've no lathe so I'd be useing forstners. Now, if I HAD a lathe I'm think'n that'd be my first shot.
Re: Baseball Stand
Gary Smyth
Since it's only the diameter of a portion of a baseball (2 7/8 to 3") all you need or want is a slight depression. A spoon bit will fill the requirement. So will a cove or round nose bit installed in a drill press and turned by hand or slowest speed. Since the ball is crystal the depression will probably be painted black anyway.
Re: Baseball Stand
Moses Yoder
I would probably turn a piece round on a lathe, then turn a slightly raised portion in the center maybe 3/4" in diameter or so, 1/4" high, and turn a slight depression in the raised portion. That way the ball would be raised off the flat piece a bit, I think this would look better. You could turn a nice design in the edge for an edge profile.
