Bath vanity boo-boo
Bath vanity boo-boo
Bath vanity boo-boo
Gary
Ok, so "boo-boo" doesn't quite fill the gist of my emotions, but I now need to fill a hole in my new bath vanity. My 1/8" drill bit went a "bit" too far when drilling from the inside of the quartersawn oak.
What would be the best way to fill this?
I'll post more info on the vanity when it is actually done (dont anyone hold their breath, now)...there are a couple of overdue thank-you's to be completed!
I couldn't get the photo uploaded....(I am not the best at computers, either), but here is the links:
http://picasaweb.google.com/lh/photo/gLCTnCRQ5ALJdHcApregXg?feat=directlink
http://picasaweb.google.com/lh/photo/NySXkQUk-wBTBr1G1VnMAA?feat=directlink
Thanks,
Gary
Re: Bath vanity boo-boo
you are in luck, maybe
bill tindall
If the hole is in the plain grain area, whittle a flat grain plug and drive it into the hole. Level it with a chisel, add a grain line or two with a pencil as needed and only you will know it is there.
Jesper, Denmark
Re: What he said, or......
Jesper, Denmark
Put in a plug of a contrasting wood and make it a feature!
Worm QSWO
Lee Schierer McKean, PA
Drill a bunch more randomly around the piece and say it is wormy QSWO. :D
I'd actually try to make a plug with similar grain.
Gary Kittleson
Gary Kittleson
that is an easy one
bill tindall
Make flat grain plug from section with no pores. Drive it in with glue. Pare off with chisel and with a brown pencil, black in a pinch, draw the grain line across the plug.
Range of options
On a rustic piece like this, Bill's whittled plug idea seems like an appropriate fix. In the contract furniture industry (and custom furniture repairing for that matter) the accepted way to touch up a stray hole or void like this would be to putty it with a water-based wood putty, level it, then paint in the background color followed by any detailing that is needed to make the patch blend in perfectly with the surrounding wood. Materials needed include a very tiny red sable artists brush (think 1/4" bristles and pointy tip), some finely ground pigment powders in various colors, and a few drops of lacquer. Dip the brush in the lacquer, pick up some pigment and paint over the patch. Follow up with grain painting or whatever else is needed to match the surroundings. On large-pored species, you might want to indent some "grain lines" into your patch a bit to maintain the right texture as well as color. Topcoat with the finish of your choice -- wiping varnish works fine, or lacquer touch up spray.
Brush size
Gary Smyth
For an item as small as shown I think the size of the brush mentioned is much too large. Think photo retouching the way they used to mask out dust. Red Sable is the right brush make up and the size can be as small as 0000. If it were mine I'd paint it in to avoid any chance of it being seen. (Remenber only you know where the error is.) If painting you will have to bleed the sides so that a circle does not appear. Take the pro fill option and purchase artist acrylics in the cadmium, umber, sienna, ochre ranges. Also white and black. Check the chart colors at the art supply or craft store (take in a piece of wood). Acrylics mix together well. Any lines are gray or brown not straight black. I'd look for a #0 regular, and a #1, #2 or #3 Red Sable liner brush and use almost dry. Do not pile on the paint. If you make a mistake (and you will) wipe down the spot with a damp cloth. Experiment on a practice hole first. You won't use even a cap full of paint total for the project. Work in pixel sized strokes, and stand back to look at it often. When fully dry, use the same clear coat as original on the whole drawer face.
Do not be shocked at the prices of the items. The paint can be $5.00 a tube and you will only brush the brush across the lid on the tube top for the paint you will need. If resealed properly it will last a lifetime though. The killer is that the brushes are so small, so expensive, avoid the strong temptation to ignore the check out.
paul in AZ
Seems like a lot of fussing about a 1/8" hole that I can't spot in the larger photo. If this was a museum quality heirloom... perhaps.
Just leave it.
