Bed Hardware Removal
I'm redoing a bed for a friend after the side rails with the slot-mounted hooks broke. I now have to remove the old hook pins buried in the head and foot boards because I'm using modern joining hardware with mortised plates. Anyone removed these things without turning the posts into firewood?
I'm thinking about using an easy-out, but not sure how hard the pins are vis-a-vis my HS drill bits.
tia
Re: Bed Hardware Removal
Hmm
Don't those things have pins through them from the side?
Re: Hmm
"Those" things (the hook plates) got trashed along with the busticated side rails.
The head and foot boards have these implanted pins to catch the hooks. They appear to be glued in so I'm wondering if anyone has been successful at removing them.
paul in AZ
I'm trying to visualize the anatomy here. What about cutting out the pins, -wood and all- the full width of the leg, and setting in a Dutchman to receive the plates? This shouldn't weaken the legs and the new wood would be on the backs of the legs so wouldn't be all that visible. Staining/matching/concealing a Dutchman in old wood could be difficult and look awful unless perfectly matched so unless this is an 'important' piece I might be tempted to use a contrasting wood -like cherry into a walnut leg. Call it a design feature.
As I understand it easy-out bits are very hard but are brittle. A line I like about the easy-out screw removers is "if it breaks you ARE screwed"
This ain't going well.
I'm beginning to hear the screech of a cut-off disc in my near future
Leo Cuellar
Re: This ain't going well.
Leo Cuellar
Is there room to do a counterbore from the back & drive them through?
AZ in Colorado Springs
Maybe you could use a tenon cutter and hog out a cylindrical space around the pins. My first thought was a plug cutter, but that's too short. The tenon cutter might leave a large bore hole, though, and you've got to get it lined up correctly.
Maybe you can leave the pins in place and work over them. You've probably thought of that, but it's another suggestion.
Cheers
FredD
If these are metal pins of sufficient diameter, drill, tap and run in a say 8-32 screw and pull them out.
FredD
They are 3/8" pins drilled from the "inside" surface where they are driven into but not through the post. I think what I'll have to do is drill a small hole from the outside surface, drive them out, and then plug the drive hole with some dowel. Just hate to mar the outside surface.
Thanks
Leo Cuellar
Leo Cuellar
What style is the piece? Rather than just a dowel, maybe a button head plug would be more aesthetically appealing. If they are 3/8", I would get a cobalt drill bit #7 and try tapping a 1/4"X20tpi hole to yank them out. If they won't just pull out, a little judicious heat application would soften/char the glue enough to allow this.
Done
Carefully located the pins and drilled a 1/8" hole from the outside and slightly into the steel pins, then, after wetting things with a little soapy water for lube, carefully drove the pins out with a length of stainless rod I had kicking around (knew I saved that for something). Now all I have to do is put a little dowel in each hole and the repair will be next to invisible.
Thanks for the suggestions, guys.
